Pics of your TV setup!
Old Feb 26, 2007 | 07:20 PM
  #31
04DarkShadowGT's Avatar
Also, note what i stated in bold....
That is a non issue on regualr style CRTs, which will give you the best picture with virtually the only draw back being size as well as limited screen size.
That being said I have zero issues with viewing angle of my projection crt. I can do whatever I need to around the house with no drawbacks at all.
Old Feb 26, 2007 | 07:42 PM
  #34
CCM's Avatar
CCM
Originally Posted by 04DarkShadowGT
Picture isnt any better either. But depending on location it can be very beneficial to have a wall mount. Like in my bedroom the 37" LCD is on the wall above the dressor. I could not have put even a 32" CRT in that same spot let alone a big rear projection tv.
Sike, plasmas and LCDs offer a far more true to life picture than a rear projection. Only a DLP rear projection even comes close, and that's only if you're sitting exactly perpendicular and center to the TV.
Old Feb 26, 2007 | 09:02 PM
  #35
No kiddin? Maybe i havent been tv shopping recently enough, but i cant remember ever seeing a single CRT projection that doesent suffer from Hot-Spotting, Some were worse than others of course, then again, i havent been TV shopping in years.
All in all there really is no certain TV that is the ultimate TV which will fit the bills for all occasions. Different TV's for different purposes.
If i end up building a home theater in the basement someday if i dont go with front projection which would be ideal i probably would go with a mammoth floor stander, just because i have room down there to house such a thing.
But up in my livingroom, no way. Forget it. Every time i go to somebodys house that has a big *** floor standing HDTV no matter where i look there it is. It is the first thing i notice and i cant seem to look anywhere without it being there. They just cannot seem to fade away or move into the background unless they are in a relativly large room, and houses up here with that size of livingroom are just rediculous in price. The one thing i dont want is something to conquer everything else in the livingroom. Down in the basement in a home theater on the other hand, hell, cant go wrong with that.
I know what you mean. I have a 27" HD (the kind that is glass) in my family room. Sits inside a built in next to my fire place. You would never know it was there. The 55" is in the basement.
Old Feb 26, 2007 | 11:30 PM
  #36
Originally Posted by PColav6
you sure do take care of them BDU's, haha
when its the weekend those things are tossed to the side. i pay this korean to clean and iron my BDU's for my alcohol rations.
Old Feb 27, 2007 | 04:23 AM
  #37
I already posted one article saying otherwise, list your sources.
Old Feb 27, 2007 | 08:07 PM
  #39
Ok I win with my 40in crt
Old Feb 27, 2007 | 08:28 PM
  #41
CCM's Avatar
CCM
I work in Magnolia Home Theater. Plasma beats rear projections (not CRTs) in every category except price, weight, and maximum viewing area.
Rear projections are dim, have horrible viewing angles, are expensive to maintain, and suffer have poor picture quality relative to a plasma because they magnify a small picture to about 1000x it's original size.
Old Feb 27, 2007 | 08:50 PM
  #43
wade95's Avatar
I'll get my pics up tomorrow. (In no way shape or form do they compare to some of you all's set ups, but for what it is I can't complain.)
Now, Im to lazy to pull my receiver out and possibly mistakenly unplug something, but how do you guys get to run two subs? Are there certain receivers that allow two subs?? My lord, that must sound awesome w/that much low end punching it's way out.
Old Feb 28, 2007 | 01:33 AM
  #45
wade95's Avatar
Thanks sir, that answered that. I have a Klipsch 10" and when it's not blowing the fuse in the back I love it. Why it's doing this is beyond me. I am not running the frequency level even halfway and normally just adjust the "volume" only. I also set my receiver at SW+8 meaning Im not running full power to the sub. Why do I keep blowing the fuse located in the back panel of the sub????? It's not often, only happens when something in it w/alot of bass spikes it hard. Come to think of it, it has never done this w/music only with movies???
I'll admit: The first time I blew it I had the freq. and volume turned up pretty far and on the "gentlemen start your engines" Daytona 500 (2004) it promptly blew the fuse.
Old Feb 28, 2007 | 05:37 AM
  #46
Dont you mean you work at Best Buy?
Old Feb 28, 2007 | 03:18 PM
  #47
I think your amp is overheating or blown out or you have reached the max vol you can go and its clipping. I had this issue with my JBL not the best sub but the price was ridiculasly low that I had to buy it. Turns out over time when sub was at idle it would get hot causing capacitors to blow out . One of the subs did blow out and the other was exhibiting the same issue, poping noises. I placed a cooling fan from a pc and powered it with a DC power pack to blow air through the amps electronics. Since then it has not had the issue. I make it a habit now to put fans on top of my reciever and inside my subs amplifier. I dont care how expensive the subs or amps you have heat is the #1 enemy and anything you can do to cool it down is going to help. I pump the volume as loud and as long as I want with no issues. If you amp is blown out the fan will not help it but you should give it a try, also touch the amp plate when subwoofer is in sleep mode to see if it gets hot if so add the fan and turn off the sub when not in use.
Old Feb 28, 2007 | 03:21 PM
  #48
Dont insult the guy Magnolia sells BB high end stuff. Its like when you go on a plane and you sit in coach, yes you are on the same airplane but the guy in 1st class is getting a much better expericence from the flight than you.
Old Feb 28, 2007 | 04:02 PM
  #50
wade95's Avatar
Thanx for the input guys. I just dont think it should be blowing the fuse at the levels I run it at. Oughta' just spend the good money and get a better sub. On that note here's my set up:
TV: 57" Ultravision
Receiver: Sony STR-DE485
CD/DVD/MP3: DVD-NCP655P
Front Channel: Acoustic Research (Sears)
Rear: Old *** Bose (these are just as good as the tower speakers, but a bit large for rear channel
Center: JBL and it's blown
Subwoffer: Klipsch 10"
Room is 14x21
Old Feb 28, 2007 | 08:56 PM
  #51
So whatcha watching buddy
Old Mar 1, 2007 | 02:11 AM
  #52
wade95's Avatar
I knew someone would chime in w/a remark. I can explain,,,really. Not in the picture was my 4 yr old and the 3month old. Wade Jr. isn't really into Barney all that much, but the baby was sitting there watching. The wife was napping on the couch. I told her "Im gonna catch hell for this picture." She asked why and I told her that I caught the picture perfect w/a Barney character.
Old Mar 1, 2007 | 05:33 AM
  #53
Thats Baby Bop dont ask how I know
jeredan2003
Nov 4, 2007 12:27 PM
dannyb785
May 20, 2005 11:07 AM
Mar 17, 2005 06:55 AM
jeredan2003
Jan 14, 2005 05:52 PM
underdog225
Oct 2, 2004 09:13 AM
