Xbox & PC integration
Old Mar 22, 2007 | 10:46 AM
Bwhipple's Avatar
In hibernation
I have no problems whatsoever. I actually stream DVD's that I have ripped onto my computer through my xbox360 onto my big screen. You do have Windows with Media Center right ?
Old Mar 22, 2007 | 11:03 AM
00blkstanggt's Avatar
Hot, Nasty, Bad ass speed
The easiest way to do it now is to have Windows Media player 11 I think it is. Before the new media player came out you had to download windows connect and that never worked for me. Update your media player to the latest and you should be able to stream music, videos, and pictures easily from your computer to your xbox.
Old Mar 22, 2007 | 11:06 AM
Bwhipple's Avatar
In hibernation
First hook the xbox 360 directly up to the computer with out using your router. This should eliminate some things. There are many things it could be. Update the firmware on your router. Check to make sure UPNP is enabled on your router. Try disabling the firewalls. Also on your router set the multicast filtering to enable. On Vista look in Control Panel/Administrative Tools/Event Viewer section and see if there are any error messages. This might help me a bit.
Old Mar 22, 2007 | 01:49 PM
If you give the Xbox number a call, they are pretty good at walking you through and helping you out. You gotta also make sure the xbox is enabled for sharing on your computer. I don't have Media Center so i'm not sure how that all works out. Sorry I couldnt help you more. You would think it should work seamlessly
Old Mar 22, 2007 | 02:03 PM
Thats weird though cause I run Norton and have no problems with iTunes or connecting 360 to the computer. Did you add the music or pictures and stuff to the shared library or whatever on the media player?
Old Mar 22, 2007 | 02:56 PM
I have no idea whats wrong then. I guess your S.O.L.
Old Mar 23, 2007 | 05:09 AM
red281gt's Avatar
Nortorn Antivirus is GAY! get live one care!
Old Mar 23, 2007 | 07:54 AM
Bwhipple's Avatar
In hibernation
If you have the guest account enabled on your computer try disabling that.
Old Mar 23, 2007 | 08:12 AM
Bwhipple's Avatar
In hibernation
Try these 2 methods to fix it
Method 1
1. Click Start, click Run, type gpedit.msc, and then click OK.
2. In Group Policy, expand Local Computer Policy, expand Computer Configuration, expand Windows Settings, expand Security Settings, expand Local Policies, and then select Security Options.
3. Double-click Interactive logon: Message text for users attempting to log on, clear any text for this entry, and then click OK.
4. Double-click Interactive logon: Message title for users attempting to log on, clear any text for this entry, and then click OK.
5. On the File menu, click Exit to exit the Group Policy snap-in.
Method
1. Click Start, click Run, type nusrmgr.cpl, and then click OK.
2. Click Change the way users log on or off.
3. Make sure that the Use Fast User Switching box is selected.
4. Click Apply Options.
Old Mar 23, 2007 | 01:22 PM
Grimmz's Avatar
Jack Touched Me...I Cried
make sure after you install Media Center you Intall the extender. If you restart your computer with MediaCenter it will tell you that it detects a 360...I uploaded all my pix and movies so I can show them on the 360 it's a bad as design but kinda slow...
Rabbit
Sep 1, 2006 11:58 AM
determined
Jul 21, 2006 07:35 AM
i love soccermoms
Dec 5, 2005 11:49 AM
stang00
24
Nov 24, 2005 12:07 AM
dannyb785
Oct 23, 2005 09:43 PM
