NEED HELP replacing pinion bearing on a 2001 v6 mustang!!!!
Old Jun 2, 2007 | 02:53 PM
dashiznit74's Avatar
Question NEED HELP replacing pinion bearing on a 2001 v6 mustang!!!!
I am trying to reaplace my pinion bearing but my haynes manual says nothing about how to remove and install the pinion bearing at all!! it tells how to remove the oil seal and reinstalling the new seal!! but has nothing about the bearing!!! does anyone know of a website that explains this or any kind of help on replacing this??? that would be great and muchly needed and appreciated if u can help out!!! thanks
Old Jun 2, 2007 | 03:44 PM
03DSG's Avatar
im not 100% sure but i think you have to take apart the entire differential to do that. so that means re-installing it is going to take some rear-end know how. if you've never rebuilt a rear end i suggest taking it to a shop. there are a lot of thomgs to pay attention too. I've found out that a gear install costs about $250-$300, so this would pretty much be the same.
Old Jun 2, 2007 | 05:22 PM
StormsGT's Avatar
1320 Number of the beast
He's right. Good time for gears
Old Jun 2, 2007 | 05:35 PM
It has to be pressed off.
Old Jun 3, 2007 | 08:18 AM
i thought it had to be pressed off but thats not the problem i am having though.... i would like to find info or step by step instructions to remove the pinion & bearing so that it can be pressed off!! thats what i need help with is removing it!!!!
Old Jun 3, 2007 | 09:40 AM
to pull the pinion.. hell that's easy. Remove the driveshaft, axles, diff, and pinion nut (you should probably have air tools or this is near impossible). Smack the pinion at the snout with a big *** hammer. The pinion pops into the pumpkin. All done. The bearing must be pressed off with a hydraulic press but it can be removed from the case with the bearing still on the pinion. Take it to a shop for the press-off press-on treatment.
Old Jun 3, 2007 | 09:45 AM
yeah u make it sound so easy but u need to check all the torques and preload specs and when the differential cover is off there is all the gearing inside there so how does the pinion just pop right out into the punpkin?? see what i need is to know how to take the diff apart and install it all correctly again!!!
Old Jun 3, 2007 | 09:53 AM
Your next statement belies this one. It would seem removal isn't your problem. Removal and reinstall is different from removal.
You can't. You don't know how so you cannot do it. Reading a book will not tell you how to read gear engagement or feel the crush sleeve pre-load. I know all the torque and preload specs but I STILL don't do my own gears because so much of it is "feel".
Take your car to the shop, have it fixed. You are stuck. I've told you twice now. Get help in person.
albo1278
Dec 4, 2008 12:27 PM
GT8600
21
Jun 28, 2008 12:43 PM
eventer289
Jan 15, 2007 05:40 AM
markm
Oct 31, 2006 04:34 PM
gyjunior50
Aug 10, 2006 06:44 AM
