Which shocks/struts?
Old Nov 29, 2006 | 09:25 AM
jstn0127's Avatar
Default Which shocks/struts?
What shocks and struts should I get for my 2000 gt vert? I already have H&R sports.
Old Nov 29, 2006 | 10:39 AM
tokico HP (mach1 struts & shocks) will be plenty. If you want adjustable then Tokico Illumina's are a good choice. If you go adjustable, definitely stay on the bottom end of the adjustment range.
BTW... this belongs in the suspension forum. Mods... if you would.
Old Nov 29, 2006 | 02:10 PM
jstn0127's Avatar
Old Nov 29, 2006 | 02:13 PM
I would only get Bilstein. Those other's are plenty good, but I like the best of the best, so I personally would pay for the Bilstein's.
Old Nov 29, 2006 | 02:21 PM
Doesn't really matter... they're valved basically identically. If you like blue, get the blue ones.. otherwise, get the black ones.
And yes, I prefer bilsteins over ANY other but for this car... they didn't seem like the ticket at almost double the price. If you decide to go more aggressive later then you'll want to revisit the shock/strut package, possibly with a set of bilsteins.
Old Nov 29, 2006 | 02:28 PM
Thank you.
Old Nov 29, 2006 | 02:31 PM
At least I don't gripe at you for moving them. It's a good policy!
Old Nov 29, 2006 | 02:43 PM
jstn0127's Avatar
I don't plan on changing the springs so the Bullitt ones should be just fine? I need to get rid of the bouncing since this is my dd.
Old Nov 29, 2006 | 02:57 PM
the bouncing? describe it please. is it literally rebounding from a single bump more than once? If so your existing struts are TOAST.
In any case, the bullits should do very nicely for you. If you don't have some MM CC plates already, do yourself a favor and get some.
Old Nov 29, 2006 | 03:09 PM
jstn0127's Avatar
I never got an alignment after the springs but I had it on the lift the other day and only noticed a slight uneven wear on the driver side front tire...thats it for having springs about 5 months now. As for the bouncing, its more of just a harsh ride. You feel every bump and you do sorta bounce once after the bump.
Old Nov 29, 2006 | 04:07 PM
All I can say to that is, "LUCKY BASTAGE". Your ride will firm up after the new dampers but it'll be (probably) less harsh. Right now you're underdamped so you're probably seeing some bottoming of the struts (harshness on big bumps) and excessive rebound (bouncing) is almost surely coming from blown struts. If you're only getting a little uneven wear on the driver side... well you're lucky like I said. If you can get a tire friendly alignment without the plates... that's really nice. If you notice uneven wear continuing after the new dampers, have your alignment checked and post the start and finish specs. I may be able to help...
Is the inside, outside or middle of your tire wearing faster? Are there any signs of cupping or feathering in any of those spots?
Old Nov 29, 2006 | 05:02 PM
jstn0127's Avatar
The tire is worn a little on the inside. Don't know anything about cupping or feathering.
Old Dec 2, 2006 | 04:41 PM
ernest russell's Avatar
Smile
what ever you put on is up to you but you should get your car lined up.r3dn3ck is trying to help you.
Old Dec 4, 2006 | 06:42 PM
jstn0127's Avatar
I know I just dont know what hes talking about when he says cupping and feathering. I bought the Bullitt shocks and got some new strut bushings from stangsuspension.com. I'll get an alignment after everything is put on.
Old Dec 4, 2006 | 07:45 PM
Smile
good, have your alinement done buy a reliable shop and they will fix you up feathering is due to the tow adjustment, cupping is due to bad struts and,or out of ballance
Psychic
Jan 24, 2009 01:26 PM
01silverbullet
Mar 12, 2007 02:17 PM
NoKturnaL
Feb 19, 2006 02:47 PM
madmatt
Jun 1, 2005 10:56 AM
bluemang417
Apr 13, 2005 08:11 AM
