steering wheel shaking?
Old Oct 23, 2006 | 10:45 AM
G PURE 260 STANG T's Avatar
I HEART MUSTANGS
Default steering wheel shaking?
today i was on the highway with my friend fooling around and i was doin about 95-100 and hit the brakes not tooo hard but kinda hard and the car started to vibrate and i felt the steering wheel shake/vibrate i was able to keep the car straight it wasnt that bad but i just dont know about the vibrating does that sound bad to you guys
Old Oct 23, 2006 | 10:56 AM
Was the brake pedal vibrating also? Could just be the ABS kicking in...
Old Oct 23, 2006 | 10:58 AM
cuban3jumper's Avatar
Your local V6 Guy
You probably have a warped rotor.
Old Oct 23, 2006 | 11:01 AM
probably more a warped rotor than abs. ABS causes the pedal to pulse but a warped rotor will shake the wheel noticably. A fast stop from 100 is enough to warp stock rotors in many cases.
Old Oct 23, 2006 | 12:01 PM
I agree with the warped rotor. You should be able to tell the difference between that and ABS kicking in.
Old Oct 23, 2006 | 12:21 PM
take this opportunity to get a set of cobra brakes on there. It's a nice upgrade and they MUCH harder to warp than 10.8" stock fronts. Leave the backs stock... no use upgrading that part.
Old Oct 23, 2006 | 04:51 PM
I HEART MUSTANGS
where could i get a good set?
how much will they be?
will i need new calipers?
and do i really need them cause i dont really have the funds now and i would much rather get some go fast parts rather then slow down parts lol would it be unsafe not to get them now?
Old Oct 23, 2006 | 05:45 PM
Find a hil and drive down it. Apply the brakes, but not too hard. Keep pressing and if the wheel rattles back adn forth, it is most likely a warped rotor. That generally means new rotors and pads, but possibly just a re-surfaced rotor.
Blake
Old Oct 23, 2006 | 07:33 PM
Like said above, its more than likely warped rotors. If you have warped rotors they have to be resurfaced and you probably need new pads as well. instead of paying the dealership 2.5 hours for the front brakes labor + parts, you should just go buy cobra brakes for 400-450 and get stainless steel braided lines as well.
Installing them is a walk in the park.
Old Oct 23, 2006 | 08:34 PM
I am doing this upgrade as soon as I need brakes.
Old Oct 24, 2006 | 08:30 AM
brake kit comes complete with rotors, calipers, pads, new SS lines, and banjo bolts. ANY IDIOT can do the swap in his driveway in 1 hour. They cost 400 bucks for the set. It would cost at least 50 bucks or so for a new rotor if you were just to replace the bad one but you should replace the front as a set. Add another 70-100 bucks for new pads cuz your old ones are probably kinda off kilter by now. So figure a minimum of 200 bucks in parts just to fix what you've got wrong right now. Add labor and you're at break even to the upgrade. With cobra brakes you'll have not just fixed the issue but made a major upgrade to performance and looks.
<My $.02>Cobra brakes are the single best investment you can make. Go as fast as you want but at least be able to slow yourself down once you get there. Stock brakes suck the big donkey *****.</My $.02>
You can go around with a warped rotor for a while and it'll just make the wheel shake a bit but it'll get worse and reduce brake capacity.
Take my advice or tell me to shove it but it's the best advice you'll get on the subject. I know how it is with money being tight but it's really really really really worth it. Really!
StaceyOi
Mar 14, 2011 02:59 PM
sand1303
Sep 21, 2008 08:27 AM
3.8LMustang
Jun 23, 2008 08:33 PM
SlicK
Aug 31, 2006 10:16 PM
Tnsweet
Apr 25, 2006 08:33 PM
