PI swap/vortech
Old Oct 18, 2006 | 05:33 PM
97stanger's Avatar
Default PI swap/vortech
i have a 1997 auto gt, with basically every bolt on you can do...my next mods are going to be as follows
Mongoose Kit SQ trim
Full PI swap
Custom grind blower cams
just curious as to how much power you guys think ill be making?
Old Oct 18, 2006 | 05:45 PM
Full PI swap
dont worry about doing the PI swap...if anything thats the last thing you wanna do cause it raises the compression....you want a lower compression for boosted applications...just get NPI cams and port you existing heads or get some VT stg 2 or MPH Race heads
Old Oct 18, 2006 | 05:48 PM
97stanger's Avatar
after weeks of talking to people about this concern, I've come to the decision that this was the way to go, I'm only going to be running 8 lbs of boost, so the compression won't be much of a concern, plus im going to get steen to dyno tune my car so i completely trust them...
Old Oct 18, 2006 | 07:03 PM
ok..then with the given mods you should be around 350-380 hp..im planning on a used KB 1.7L and puting a built bottom end in mine w/ low compression pistons if i can so i can boost the S*** outta my car..hhaha..but teh bottom end wont come anytime soon
good luck
also..where are u from? im assuming near steen racing...if ur more north (like around PA area) id recomend going to Lund racing...i know a guy that doesnt go to anyone but him....he got tuned for the street @ 750+hp
Old Oct 18, 2006 | 07:14 PM
97stanger's Avatar
i actually live in nj, near atco raceway, where steen is always at...wow thats a lot of hp for a stang!!
Old Oct 18, 2006 | 07:32 PM
there are alot of high power stangs in this area...and since u live right next to PA just go to jon lund in PA...i dunno exactly where he is located...but the one thing i do know is that he near me in chester county cause his number is 610 as is mine
lundracing.com
and check out SVTP's "a taste of home" forum...then go to Midatlantic Cobra Association....that all of the Mid atlantic states in 1 forum.haha..look at their sigs and most have tuned by jon lund/lund racing
Old Oct 18, 2006 | 09:09 PM
97stanger's Avatar
okay ill definately check it out!
Old Oct 18, 2006 | 09:17 PM
Why do you need a PI swap?? Just run more boost. Youll make around 400whp since thats what your stock bottom end is limited to....
Old Oct 19, 2006 | 07:18 AM
97stanger's Avatar
you can't run more than around 10 lbs on your stock block...and 10 lbs on my non pi stuff won't yield much more than 300whp
Old Oct 19, 2006 | 03:40 PM
DropTopPony's Avatar
your gonna drive all the way down to Steen for a tune? I like them and they will be building my Teksid block but there are a few good tuners in our area. How about Radical Racing in Atco? Craig is very good...or JD's just outside Philly who are good. Then you have Kauffmans in Dilsburg PA who i think are at the top of the list with the best tuners for modulars anywhere. Totally worth the 2 hours drive.
Oh what wheels are they on your car? They look similar to a set i used to have.
Old Oct 19, 2006 | 05:02 PM
97stanger's Avatar
well i was thinking of going to JDM, im going to get some prices and see whats the best...by the way, they are 18x9 chrome saleens
Old Oct 19, 2006 | 05:11 PM
ex-ricer98gt's Avatar
talk to todd at kaspers korner right in blackwood he'll hook it up he know's his ****
Old Oct 19, 2006 | 05:15 PM
I recommend Dave @ Kauffmans or Matt Hill @ www.matthillmotorsports.com
Old Oct 20, 2006 | 01:06 AM
dave is a cool dude tuned a couple of guys cars from dover delaware.
Old Oct 20, 2006 | 08:24 AM
Those are Saleen wheels in the sig pic?
Kaspers has a dyno in their new shop?
Old Oct 20, 2006 | 09:14 AM
97stanger's Avatar
oh sorry, no they're zenettis...my saleens are my summer rims
Old Oct 20, 2006 | 09:25 AM
if I might pop in for just a second. You want to run 8psi on a 10:1 compression motor with hypereutectic pistons. If you're really sure you want to do that (don't get me wrong, I know this to be a really powerful combo but let me finish) then you really should build the bottom end. Sorry to be a negative nancy but I've seen it before enough times and it's just a matter of time before the bottom end gives out and you're stuck with a rebuild (just bolts and gaskets are $300+, assembly is 1000-2500). Or you can find a 99+ short block and just bolt it up so to speak.
You've got PI heads and intake, find yourself a 4.6 block on craigslist for cheap and spend the 300 bucks to machine it then buy a forged rotating kit and have it all put together. It's gunna be kinda expensive and it'll take a while but when you're done you can be happy knowing your motor will hold together when you're smoking a chebbie.
Old Oct 20, 2006 | 09:37 AM
Mug11's Avatar
costing me about $2k to build my shortblock right now. so if yours blows dude, you can have my stock one. But blower cams FTW. See pm... lol
Old Oct 20, 2006 | 09:48 AM
2K... lucky! I've got that and then some in the 5.4 I'm building now and there's still another 3K to go.
usaf88
Oct 8, 2009 04:31 PM
2Eighty1
Apr 2, 2007 09:10 PM
jasons 97 cobra
Feb 28, 2005 01:13 AM
jasons 97 cobra
Jan 19, 2005 09:15 PM
Nov 29, 2004 04:06 PM
