Help with Tranny
Old Oct 13, 2006 | 06:08 PM
Stang28's Avatar
Default Help with Tranny
I put on a new clutch cable and my car still wont shift gears. My quadrant is fine so no need to change it. When the car is running it wont shift gears, but when the car is off it will shift gears. The part I am clueless about is my car will start when I engage the clutch. Any clue what it may be?
Old Oct 13, 2006 | 06:49 PM
When you replaced the cable, did you adjust it?
Old Oct 13, 2006 | 07:19 PM
Stang28's Avatar
I did but the cable seems to still have some play in it.
Old Oct 13, 2006 | 07:26 PM
Do you have an OEM or adjustable cable?
Old Oct 13, 2006 | 07:36 PM
Stang28's Avatar
Adjustable
Old Oct 14, 2006 | 08:55 AM
never ever been happy with adjustable cables. OEM. Try readjusting. The reason you can't change gears when it's running is the clutch is still engaged. You need to adjust the thing until it's not engaged.
Jack up the back end so the wheels are off the ground. Peg the clutch pedal to the floor with a stick or something (a friend is really helpful here). Adjust the clutch cable and firewall adjuster until the rear wheels don't turn with the tranny in gear and the clutch pedal to the floor.
You're welcome.
Old Oct 14, 2006 | 12:57 PM
Stang28's Avatar
You're welcome.
Ok, I will try that. Thanks
rptshame
Apr 7, 2010 11:47 AM
joeboy013
Sep 4, 2006 08:13 PM
66pony
Feb 12, 2006 09:05 AM
66pony
Jan 20, 2006 11:09 AM
66pony
Dec 16, 2005 10:27 AM
