dumb question....
Old Sep 17, 2007 | 10:21 PM
Default dumb question....
is it ok to disconnect the power steering lines that come out in front of the radiator? I mean is it pressurized? I didnt think it was. Is it ok to get some air in the lines? I may need to disconnect the lines and relocate them so I can get my intercooler sitting in the right spot......
Old Sep 18, 2007 | 06:14 AM
It is OK but you need to bleed the system afterwards.
Old Sep 18, 2007 | 08:09 AM
how do I do that? Need any special tools?
Old Sep 18, 2007 | 08:35 AM
That I'm not so sure but I bet you have to bring it to someone to do that.
Old Sep 18, 2007 | 02:22 PM
You don't have to take it anywhere its just a process that must be done to get air out. I will look in my manual when i get home. Its just a matter of turning the steering lock to lock for so long and in some order i dont remember off the top of my head.
Old Sep 18, 2007 | 03:06 PM
eh.....I really dont feel like relocating anything else. I want something that will bolt on without any modifications.Still maybe going with the paxton kit.....
Old Oct 4, 2007 | 11:55 AM
El Diablo's Avatar
When you disconnect the lines, transmission fluid will come out pouring out. The way you bleed the system is by turning the steering wheel from side to side. The fluid you put back in is atf transmission fluid not the standard brake fluid.
I just extended the lines to sit infront of my intercooler...
Old Oct 4, 2007 | 12:48 PM
Mixedbreed02GT's Avatar
why in the hell would transmission fluid come out of the power steering lines?
Old Oct 4, 2007 | 12:53 PM
El Diablo's Avatar
Thats what is used from the factory...Disconnect your lines and I bet red fluid comes out or look in the brake reservoir...
Old Oct 4, 2007 | 12:54 PM
Ford uses Mercon (or Mercon V, don't have my manual on hand) ATF for PS fluid.
Old Oct 4, 2007 | 12:58 PM
El Diablo's Avatar
Thats sound right...
Old Oct 4, 2007 | 01:43 PM
just goes to show that you learn something new everyday, because I did not know that.
Old Oct 4, 2007 | 02:39 PM
ernest russell's Avatar
Default powersteering
ford uses mercon automatic transmission fluid. remember it does not mix with mercon v
Old Oct 4, 2007 | 07:54 PM
yea tranny fluid is used in more than transmissions. Ive seen people even put it in their motor....
m0nkeh
21
Dec 31, 2005 01:19 PM
Jack The Ripper
Jul 24, 2005 10:38 AM
B-rett
Jul 16, 2005 08:46 PM
MineralGT
Jun 29, 2005 10:48 PM
bucky
Apr 13, 2005 03:02 PM
