Cams worth it?
Old Jul 1, 2007 | 03:26 PM
Default Cams worth it?
My engine build is getting on its way. Rods are ordered, then pistons and crank. After that all I need is oil pump, gaskets, fasteners, rings, and bearings. I dont feel like saving the extra $$$ to have the heads ported. I may clean them up a little by hand. Would it be worth it to add cams to my setup on non ported heads? What kind of HP gain is it worth running 16psi on 8.5:1 or 9:1 compression?
Old Jul 1, 2007 | 03:37 PM
hell yeah blower cams are worth it. im sure with 16 psi and race gas that should put you in the higher 500 hp range.
Old Jul 2, 2007 | 01:23 PM
B-rett's Avatar
BMC Member# 03209
in my opinion the lope makes them worth it to begin with the power is just a bonus lol
Old Jul 3, 2007 | 11:20 AM
they're complimentary mods but the cam is more important. You might make 15-20hp NA more with porting but with the right cam you can make 20-30+hp with stock heads.
See if you can find a used set of ported heads... I found some for 400 bucks. I sold some for about that too. If nothing else grab a die grinder and a carbide bit and gasket match the intake port. Don't get real far into the throat without more research though or you could lose flow.
sbrooks
38
Oct 12, 2006 04:12 AM
HappySavage
Mar 20, 2005 09:24 PM
WaterDR
Feb 4, 2005 05:42 PM
EH819
Jan 28, 2005 09:12 AM
p3s7_01
Jan 19, 2005 06:09 PM
