Noisy rockers
Old Apr 23, 2007 | 07:04 AM
Venona83GT's Avatar
Question Noisy rockers
I have an 83 GT with 302HO we rebuilt the engine 2yrs ago mostly just mild upgrades mild cam,lowprofile aluminum intake,holley 4brl,headers. It runs like a bat out of hell but I have allways had noise in the valve covers like valves or rocker ticking. I tried new push rods not much diferance. doesn't seem to be any wear on the rockers(not replaced)what else can I try without spending a fortune?
thanks,
Venona
Old Apr 24, 2007 | 07:45 AM
The first and more then likly reason why its making noise is improper valve lash and or some other sort of valve train binding. I would start by rechecking all the valves lash and make sure there to spec. That can cause alot of valve train noise if there too tight or to too loose.
Old Apr 24, 2007 | 10:35 PM
ClemsonStang's Avatar
what year is the motor?
Old Apr 25, 2007 | 05:12 AM
Venona83GT's Avatar
Thanks and I will check into that. And the motor is also an 83.We checked the vin#it shows to be factory 302HO we asume its the ariginal.
Old Apr 25, 2007 | 06:24 AM
83 is a non roller motor. could be a lifter or a rocker. could be many other things. have to hear it, see it, and play with it. line the fender with a towel, pop the valve cover off and fire it up. make sure your getting oil up through all of the push rods. sounds like a lifter or a rocker. ive got a full set of 16 rockers from my 87 motor that i would send you for $10+ shipping...
GDP
May 8, 2009 05:41 PM
mustangV6_04
Dec 29, 2008 02:58 PM
kshmny925
Aug 14, 2006 06:53 PM
Cruzang
Jul 24, 2006 02:22 PM
p3s7_01
Dec 28, 2004 11:43 AM
