blew my engine in my 4v
Old Apr 14, 2007 | 11:58 AM
32vRacer's Avatar
Default blew my engine in my 4v
SUCKS!!! started hearing a vigorous tap on acceleration only after 2k RPM. thought maybe it could be a vibration. than found out i had a cylinder 6 misfire. took it to ford and they broke the bad news to me. they told me that it was a definante bottom end problem. that 90% chance the motor has to come out. i am screwed, just bought the car in feb. wit 43k miles.....so the odometer says
Old Apr 14, 2007 | 12:38 PM
TClark22's Avatar
Blown 2V
damn the 4v motors are dropping like flies...2 people around kansas city just blew theirs...and with the same amount of miles
Old Apr 14, 2007 | 12:45 PM
yea that motor is definately coming out. Sorry to hear it but use this time to upgrade if at all possible.
Old Apr 14, 2007 | 01:25 PM
99-01 cobra or 03-04? One is much cheaper to replace than the other.
Old Apr 14, 2007 | 05:46 PM
3V2000GT's Avatar
46MONSTER
dang that sucks I was in the same situation a year ago. Forge everything its the only way to go.
Old Apr 14, 2007 | 06:42 PM
32vRacer's Avatar
its actually a 97
Old Apr 15, 2007 | 01:44 AM
White04GT's Avatar
KenneBell Blown
drop a 01 engine or a 03-04 mach in it.
Old Apr 15, 2007 | 09:17 AM
Thats bad but I would rebuild your current block with forged internals and add a power adder later on. Get an oil pan with larger capacity our 4vs love the oil due to the heads.
Old Apr 15, 2007 | 10:01 AM
ClemsonStang's Avatar
yeah, ide drive a honda for a few months and put a pretty solid low compresson bottom end in it. then boost it later.
Old Apr 15, 2007 | 10:41 AM
you can just find yourself a used shortblock from any 96-04 car and bolt it up. It'll be the equivalent of a head gasket change since you're basically swapping the heads and such to the new block. Compression will drop a point with dished pistons.
I'd buy a built short block if you can afford it. Single best option.
Old Apr 16, 2007 | 04:32 PM
32vRacer's Avatar
well heres the deal. i talked to a journeyman mechanic at a dealer and he said hell do it on the side for 2300. thats pulling the motor, fixing whatever needs to be fixed, and putting it back in. not including parts. for parts im looking at maybe a rod or two he said, or bearings. worst case scenrio a crankshaft, but doubts it. so im lookin at maybe 3k to spend. is there anything else i can do with my 3Gs?
Old Apr 17, 2007 | 03:31 PM
Old May 6, 2007 | 02:14 PM
32vRacer's Avatar
ok, blocks at PER race engines in plainfield IL. crankshaft scored to ****. ordered 1 from jegs. theyre gonna hone the block pressure checke veerythin balance everythin and put the long block together for 1200. he says hell bevel my valves for 380 and ill get 15% increase in airflow...he equates that to about 20 hp, is he being a little generous with his assumption?
TonyStangs
Dec 26, 2006 12:27 PM
3V2000GT
51
Apr 25, 2006 08:36 PM
dom
Jan 29, 2006 10:43 AM
dom
27
Jan 16, 2006 10:08 AM
SpinMedia
20
Nov 26, 2005 03:34 AM
