Transmission Fluid?
Old Mar 23, 2007 | 03:14 PM
00blkstanggt's Avatar
Hot, Nasty, Bad ass speed
Default Transmission Fluid?
I was just wondering how much transmission fluid my car takes and what kind I should use? I have a T-45 transmission.
Old Mar 23, 2007 | 04:05 PM
ShapeShifter's Avatar
awesome i was just gonna post a thread like this,so in addition to his question..what about mine...its a 2001 GT Auto
Old Mar 23, 2007 | 04:27 PM
damn, just when I thought I had a response. haha
Old Mar 23, 2007 | 08:43 PM
It's friday were getting drunk give us a break anyways .....
T-45=3.25Qts ish
the Auto transmission is a little over 12 quarts
Old Mar 23, 2007 | 10:33 PM
I believe you fill it until level w/ the fill hole. I might be thinking of the T5 but I'm pretty sure it's the same.
Old Mar 23, 2007 | 11:11 PM
T-5 is a bit different the t-45 and the 3650 are the same though so maybe the manual guys could chime in here to double check my s***
Old Mar 24, 2007 | 09:10 AM
Well, my manual for the TR3650 says to fill below the fill hole (should only feel the fluid when you stick your finger in it). If the TR3650 and T45 are the same in that aspect, then that's the method if you are going by that.
Old Mar 24, 2007 | 03:22 PM
Check this out....My car shifts like butter now!
https://mustangboards.com/general-te...h+transmission
Old Mar 24, 2007 | 03:39 PM
StormsGT's Avatar
1320 Number of the beast
just did mine yesterday and used Royal Purple. It was a tad less then 4 qts. I can feel a differance in it too,its smooooother.
Old Mar 24, 2007 | 03:52 PM
what tranny do you have in your slowbra?? ha ha...just kidding. 4 quarts is too much fluid for the 3650's. 3.17 quarts is the proper amount per tremec.
Old Mar 24, 2007 | 04:22 PM
StormsGT's Avatar
What do you have to be hurtful for? Its a T-45 and I said a tad less then four,but you'll have to buy four.
Old Mar 24, 2007 | 04:30 PM
mcmmotorsports's Avatar
Resident Mental Patient
You do know that Lucas sells a Semi-Synthetic ATF? That is what I have been running for about 2 years now.
Old Mar 25, 2007 | 08:13 AM
03DSG's Avatar
so does anyone have any pics or a write up on how to change the fluid in a 3650? I have 50k and its time, plus over the winter i had the second gear clashing thing going on...
Old Mar 25, 2007 | 09:00 AM
yes, I do know that. Several well respected mach owners recommended it so I tried it, and it works great.
Old Mar 25, 2007 | 09:25 AM
I use amsoil ATF and I short the 3650's by a half quart from spec so it shifts easier when cold.
Old Mar 25, 2007 | 10:01 AM
Thats what I use but I have hard shifting. Im gonna throw some Lucas Tranny fix in and see if it helps. Im already at the correct level.
Old Mar 25, 2007 | 08:02 PM
blackstang01's Avatar
so does this filling procedure work for the t-45? 3.15 qts?
Old Mar 25, 2007 | 08:07 PM
1. Jack up car (only really need the front up).
2. Unscrew the drain plug (plug uses a 3/8" drive w/ no socket and is located at the bottom of the tail housing).
3. Once fluid is fully drained, put plug back in and undo the fill plug (looks exactly the same but it's located on the passenger side of the tail housing about 1/4 of the way up).
4. Fill w/ 3-1/4 qts of a nice synthetic Mercon/Dexron III ATF (I recommend Redline D4 ATF).
5. Once filled, put plug back in, lower the car, and your done.
Also, try to change the fluid while warm since the fluid will be able to suspend any particles better therefore making your fluid change more effective.
Old Mar 26, 2007 | 06:31 AM
so does the fluid pour right in or do you need one of those hand held pumps?
Old Mar 26, 2007 | 06:51 AM
a pump makes the whole process easier and less messy. i havent done it any other way but its kinda tight in there.
Old Mar 26, 2007 | 06:52 AM
Get the pump. The one I got from Sears was a nice piece that attaches to the bottle.
Old Mar 26, 2007 | 09:24 AM
yeah.. they're like 7 bucks and infinitely useful for the shadetree mechanic.
Old Mar 26, 2007 | 01:38 PM
Thanks for the info fellas.
Old Mar 27, 2007 | 07:09 AM
03DSG's Avatar
thanks man, thats going to be an up comimg project....
NeedACobra
Mar 21, 2009 01:25 PM
theponyfactor
Jul 9, 2007 06:51 PM
dmkx3
Mar 18, 2005 04:16 PM
my2001GT
Mar 10, 2005 08:40 PM
EH819
Jan 9, 2005 08:51 PM
