advice needed for sirius radio
Old Apr 18, 2007 | 06:27 PM
arodriguez05's Avatar
Default advice needed for sirius radio
I am tired of leaving my sirius tuner on after forgetting to turn it off when exiting my car. I currently have it powered by using the cigarette lighter adapter it came with. My question is, what would be the best wire to tap into for a keyed on switch? Or is there a better way?
Old Apr 18, 2007 | 09:07 PM
Yes it does, but I believe it is the same way as the other lighter connector. I think I tried that already, but I will make sure though...thanks
Old Apr 18, 2007 | 09:11 PM
If you remove the plastic plate under your steering wheel, you will find a red wire with a green strip. This is a "keyed-on" power supply. You can then buy a cigarette lighter adapter and wire it to this wire and a ground. Then, just plug in the radio right into it and hide it.
Old Apr 18, 2007 | 09:26 PM
water do you have any idea if this wire would be the same on an 06? knowing where a keyed-on power supply is might come in handy later
Old Apr 18, 2007 | 09:30 PM
No.....but, there a a bunch of places. I fyou look at your fuel injectors, you will see that one of them has an extra wire, for example. This should be the "keyed-on" power.
Old Apr 18, 2007 | 09:41 PM
is it always red with a green strip too?
Old Apr 19, 2007 | 05:45 AM
I have always found an ignition on power lead on the fuse box usually without a fuse. My wifes car Cig light turns off when car is powered off but Im on the same boat as our stangs always have current. I may just run the positive from the cig lighter to the fuse box ignition source.
Old Apr 19, 2007 | 05:14 PM
When you say buy a cigarette lighter adapter do you mean a different one then the cigarette lighter power supply adapter it came with? or could I just cut the end that plugs into the lighter on the existing adapter, but would I still need a ground?
Old Apr 19, 2007 | 07:11 PM
Easiest way would be to cut the power cable from your existing cig lighter and connect it to an ignition source. The other option would be to hard wire it .
Old Apr 19, 2007 | 10:15 PM
I'm thinking the best option might just be to hard wire it. I think it would look cleaner to completely get rid of the exposed lighter adapter that reveals wires and also prevents me from showing off my shiny steeda lighter lol...maybe I can wire it into the power supply to my cd receiver which is keyed on? wonder if that would work?
Old Apr 19, 2007 | 10:35 PM
You can do that. You can buy a 2 cig splitter hard wire that then connect your sirrus and have an extra connection for a cell phone charger, that way you wont damage the sirius car charger and have another port open for something else. Where are you going to mount your sirius? I put mine right on the shifter bezel below the radio mounted horizontal.
Old Apr 20, 2007 | 04:49 PM
Good idea, I just did mine the lazy way and vent mounted it. Did you use a special bracket to install yours there. Mine really doesn't give me any problems where it is mounted and has easy access to the screen and functions.
Old Apr 20, 2007 | 08:18 PM
I used the flexible stickon bracket which cannot be seen since the unit is vert. I ll post a pic so you can see. Its out of the way and in a dead space. I have the S50 so it may not look right with the older models.
Old Apr 21, 2007 | 03:30 AM
You can buy a cig adaptor at radio shack and it has a built-in fuse. This is the style with a female end. You hard wire this to the power on supply and then plug the XM radio into that. This way you can always unplug the radio in the future and easily plug anything else into it.
Old Apr 21, 2007 | 06:45 AM
or ya could find an aftermarket radio that's sirius ready...it's what i did w/xm, and ya don't see anything cept the antenna...no one know's it's there :-D
Old Apr 22, 2007 | 07:27 AM
Here a few pics of my setup as you can see it can swing to many places and I do not have issues with shifting. I leave it like the 1st pic below but its good to know that I have options as far as position.
Old Apr 29, 2007 | 12:08 AM
that is a real nice setup!
cubfan65
Aug 24, 2009 10:41 AM
Rob13288
Apr 15, 2009 12:52 PM
arodriguez05
Sep 26, 2006 06:51 PM
Chopper
Feb 27, 2005 11:51 PM
rebelyell
Jan 24, 2005 10:13 AM
