Max 4.6 while maintain Boost Cap.
Old Feb 13, 2007 | 12:32 PM
stang671's Avatar
Default Max 4.6 while maintain Boost Cap.
Hey,
I was wondering if anyone knows the amount of hp a 4.6 2v can produce and still maintain the capability to use boost....the I have 97Gt that and i'm doing the upper PI setup and I was wondering about the rest of the engine...i understand to put in the Forge internals and all but i was wonding about the cam setup and etc...i also understand that boost and all depends on compression...and i know that most hp cars N/A have high compressions so I was wondering if anyone has put on together a great combination that works.....thanks for taking the time to read this...
Old Feb 13, 2007 | 01:59 PM
You'll want to do a lot more research to fully understand what's happening.
First, a PI swapped 96-98 motor is probably not a good candidate for much boost unless the bottom end is rebuilt with lower compression pistons and forged rods. 10:1 would be the starting compression and while our modular motors do very well on paper with 10:1 and 8-10lbs of boost that sort of combo usually requires race gas to avoid detonation.
There is no limit to how much hp your motor can make before you add boost. It's not written anywhere. The TOTAL output of your motor including boost, effective compression ratio, cam selection, etc... is a little important but the build of the bottom end and the tune are the secret sauce for longevity.
If you're going to PI swap it and add boost, then transplant a 99-04 motor complete and then add ~8lbs of boost with a nice conservative blower cam (VT stage 1-2). In any event I don't generally like boost on unbuilt motors. It's just asking for trouble.
With just a PI swap you should see from 260-300rwhp on a decent tune. That's plenty for most people, if you need more try a 75hp dry shot of nitrous. At least you can turn that off when you don't need it.
Old Feb 13, 2007 | 02:15 PM
Max on stock internals is ~400rwhp.
Old Feb 13, 2007 | 05:20 PM
stang671's Avatar
I understand that the stock internals can only handle bout 400rwhp that's why i was stating that I was going to use forged internals......i'm thinking about adding a 2.1 KB ontop once it's all done...so i'm trying to get the most out of my N/A then having the KB so I was wondering what do you think is the best way to go about having that hp and still being able to run decent boost and hp....thanks for taking the time to read this...
Old Feb 13, 2007 | 05:37 PM
Ok, built long block from Tim @ Modular Powerhouse. Ported PI heads, custom cams, built iron or aluminum block. The only thing holding you back then is the fuel system.
For the fuel you could go with CRP rails, GT40 dual pumps in cobra tank with dual upgraded FDPM's and fuel lines. Another option is dual focus pumps and larger fuel lines.
All depends on how much power you wanna push and the amount of money youve got.
Other choices for the long block would be Steen Racing, Fox Lake, or VT Engines.
Old Feb 13, 2007 | 05:43 PM
stang671's Avatar
Ok, ported heads and custom cams from Tim @ Modular Powerhouse. Drop the compression down a bit. The only thing holding you back then is the fuel system.
All depends on how much power you wanna push.
I have ported PI heads already...other then that I'm just replacing all the internals....my intial goal is 550 rwhp..i was hoping to get that on pump gas (91 CA) but I was told that's not possiable and I could only get about 500 rwhp so i'm kind of stuck on that....even though i'm sure 500rwhp is plenty for street/strip (but mostly street) I just want to be able to beat 90% of what I line up against espically those imports cause i know their much lighter....and then I want to crank up the boost to 20 if i need to....but that is my goal...and I do have access to 100 octane if need be at $6.99 gal...LOL...thanks for taking the time to read this....
Old Feb 13, 2007 | 05:46 PM
Who told you that you cant get 500rwhp on pump gas? Its 100% possible. 100 octane would give you even more. Since youve already got the PI heads ported, Id get some custom cams from MPH, and a built block from them. http://modularpowerhouse.com/product...f43462ce43593d
http://modularpowerhouse.com/index.p...f43462ce43593d
Old Feb 13, 2007 | 05:48 PM
Ever consider a 4v 4.6 swap with a twin turbo setup? 700rwhp is baby steps on a 4v setup.
Old Feb 13, 2007 | 05:50 PM
stang671's Avatar
I was told and i read on different forums that it's not worth it to change out a 2v with a 4v with all the emissions and stuff i'd have to do...and I'm military so i have to keep the car legal (CA) other wise i'd go TT....thanks for taking the time to read this...
Old Feb 13, 2007 | 05:51 PM
stang671's Avatar
I was orignally going to stay with 91 and try to get 500rwhp with that octane...but the shop said that it can't hold those horses....and would it be cheaper to buy the block or have my rebuilt with forged internals...thanks for taking the time to read this...
Old Feb 13, 2007 | 06:42 PM
You can get 500rwhp with 91 octane. Just buy the short block from MPH, then sell your short block. If you keep your stock block then youll still need to machine it and stuff.
Old Feb 14, 2007 | 06:08 AM
Turbo 2v can make tons of power. thats the road i would go if i had a built short block and ported heads.
Old Feb 14, 2007 | 06:12 AM
stang671's Avatar
I can't go turbo cause i'm military....and i have to stay legal to be going back and forth on base....i can't take the risk of my car being searched and then they taking my car cause it's not street legal and defin...not base legal...thanks for taking the time to read this....
Old Feb 14, 2007 | 07:13 AM
01GTBlown's Avatar
"kill or be killed"
Not street legal or base legal? What? You can bolt a turbo on and still be street legal, i dont know what the base rules are but this doesnt make any since.
Old Feb 14, 2007 | 07:25 AM
you're in california... damn that changes lots of things.
stick your compression at 9:1 and you can run 12-14lbs without having too many tuning nightmares. I'd stop at 12. make sure you build the hell out of the motor.
Old Feb 14, 2007 | 09:01 PM
stang671's Avatar
thanks ill try and do that...i'm not trying to find where i can get a good built motor and a good deal at....03gtmustang stated to get one from MPH so i'm going to look into that...and some other places if you can recommend a place then that would be great...and 9:1 is ok with CA 91-octane right?...thanks for taking the time to read this....
Old Feb 15, 2007 | 09:16 AM
9:1 will allow you to run quite a bit of boost without losing too much low rpm and part throttle grunt. I'd probably stop at 12lbs of boost non-intercooled or 14lbs intercooled but I'm the conservative type. A side effect of dropping compression is it's usually easier to pass the sniffer with lower compression than higher.
What base are you at? If you're in the SF/Sacto area I can point you to some boards where they can provide much more detailed information and help that's specific to california and Smog Check II.
As for engines... MMR, MPH, VT have all been doing fairly well. I have not heard many complaints about any of them. CHP on the other hand I have seen some modulars fail at the main bearings so I'd leave them to the pushrod motors where they've been doing great for a long time.
Old Feb 15, 2007 | 01:12 PM
stang671's Avatar
No i'm stationed down in San diego...im thinking about just getting my block rebuilt and going from there with all forged internals and putting the p/p PI heads and the PI intake ontop....ok the 9 it is...the next thing i have to do is find a good tranny (auto) and a desent rear-end to handle the hp...thanks for taking the time to read this...
Old Feb 15, 2007 | 01:17 PM
Contact Darrin @ www.bc-automotive for your auto needs. For the rear, Id go with Moser 31 spline axles without studs and a 03/04 Cobra posi or Eaton posi. What gears are you running? While you're doing the rear end work, Id also weld the axle tubes and torque boxes.
I can recommend some suspension stuff after I know how far you want to take this car.
Old Feb 16, 2007 | 01:52 AM
stang671's Avatar
I was thinking about getting the strange rear-end setup...and going with 4:10 I was told that would be a good setup for a KB...but what do you think about that...then I was going to get the PA transmission...those are just thoughts on that though...and then after I get all that done I was going to go with the Max...setup...thanks for taking the time to read this.....
Old Feb 16, 2007 | 06:50 AM
max is a funny term... it doesn't apply or even exist. apart from that...
whatever you get... tell the guy at the sales desk that you plan on spitting 500+rwhp through it and that you'd like it built to handle that. After that... good luck. I'd recommend adopting a bi-monthly maintenance regime that includes thorough inspections of all the things you change if you're gunna daily drive it. Power costs maintenance.
Old Feb 16, 2007 | 07:15 AM
stang671's Avatar
I appoligize i was refering to Maximum Motorsports...and thanks for the Luck...maybe one day I'll see you when I go home (the Bay area)...thanks for taking the time to read this....
roccococo
Announcements & Contests
Sep 8, 2014 04:36 AM
satchmo72
Feb 12, 2012 03:04 PM
dannyb785
Mar 30, 2005 10:10 AM
Jan 15, 2005 05:58 AM
808GT
Jan 1, 2005 03:01 AM
