Need Advice
Old Feb 1, 2007 | 01:43 PM
race101's Avatar
Default Need Advice
I just bought Underdrive pullieys and I'm gonna get them installed over the weekend and my question is.. should i advance my timing?? if so, by how many degrees?? and is it worth me advancing my timing?? my engine is completely stock, the only thing it has is: K&N Intake, Catback Flowmaster Exhaust, and soon to be BBK Pullies..
Thanx
Old Feb 1, 2007 | 01:47 PM
97stanger's Avatar
you dont have to, your motor doesn't have that many mods where it would help that much. good luck on the pulleys.
Old Feb 1, 2007 | 02:49 PM
Do you have a timing adjustor or chip? If not then how are you going to advance your timing?
Old Feb 1, 2007 | 03:50 PM
race101's Avatar
take it to a shop
Old Feb 1, 2007 | 10:57 PM
caballo's Avatar
Exceptional Member
Originally Posted by race101
take it to a shop
Just wait till you get more mods... like a mid pipe or cams or maybe gears, then get a tuner and take it to a shop...
Old Feb 2, 2007 | 02:51 PM
a shop will have to chip it or otherwise tune it or install an adjustable timing wheel like steeda makes. In any case that's a global adjustment to an electronically controlled motor. You'll get maybe a couple hp peak from it and have worse drivability. Get a power adder and then you can mess with the timing.
Old Feb 2, 2007 | 03:01 PM
take it to a shop
And what is the shop going to do without a chip or timing adjuster in the car?
Like red said, using a timing adjuster like Steeda's is the wrong way to do it.
Old Feb 2, 2007 | 08:26 PM
Ain't like the old days. You can't just advance the timing as easily as you once could.
You either need a chip or hand-held tuner OR a Steeda Timing Adjuster. A tuner/chip will adjust the timing proportionally just like the car currently does. A TA will adjust the timing the same across the board.
IMO, a TA is really only good for a Drag car. When racing, you are prety much at WOT the whole time and the rpms are abover 4,000. This way the driver can tune the car by hand for higher octane fuel then return to the street and pull the timing back to normal.
FritoBandito
Aug 25, 2005 04:14 PM
Texas Mustang GT 2003
Jul 17, 2005 09:07 PM
witestang
Apr 20, 2005 07:39 AM
speedshift86
Feb 4, 2005 01:09 AM
Stangdude27
Jan 13, 2005 07:46 PM
