To Rebuild or not?
Old Jan 22, 2007 | 04:00 PM
Grimmz's Avatar
Jack Touched Me...I Cried
well if your talkin abotu cheaper, buyin a used Mach 1 is probably alot cheaper then redoing EVERYThing in your 6banger, theres alot more upgrading to a V8 then you might think...
Old Jan 22, 2007 | 06:25 PM
05+ GTs are now under 20k.
Old Jan 22, 2007 | 07:25 PM
oh yeah the 05+ are getting cheaper I found one the other day for $17k and only had 18k miles.
Old Jan 24, 2007 | 07:25 PM
95STANG's Avatar
In heven there is no beer
If you want to make all the V8 boys cry, go with the built 6. Im in the same boat u are, deciding whether to spend money on the 6 since it is my first car or look around for a GT.
Old Jan 25, 2007 | 05:51 AM
Teal_Beast's Avatar
V6 Power
I would say get a cheap crate motor from RPM and call it a day, you dont have to go nuts with it but forged pistons/rods (only I beams) get some CNC heads to go with it, a cam etc and set it up to hold the power. you dont even have to go to a 4.2 if you wanna save the money
http://rpm-mustangs.com/cart/product...roductid=16368
4 grand gets you a extreamly solid motor that should be good to well over 500whp (hell Matt is only using I beams and he is at 600whp+ from an AUTO!)
The drop in is direct so there is no bullshit wiring to deal with, just swap in, swap out.
that or you can do it the long way and get a local guy to rebuild it.
Old Jan 30, 2007 | 02:50 PM
the gillz's Avatar
Bruce Leeroy
well if its not going to be a daily driver then check into swapping a 5.0 in there. thats what im in the process of doing. rebuilt 5.0's arent too expensive. Found mine for $900 with the GT-40 heads on it. No more AC, computer, harness, nada. Just a carb, 5.0 and a LSD. thats all i need. Not to mention I havent seen many 99-04's with 5.0's. The T-45 tranny will work and so will my 7.5 rearend. Its got 3.73 and a factory t-lok. The motor itself probobly puts out what like220 rwhp. The stock tranny and rear will handle that no problem.
F8L STANG
Mar 2, 2006 04:06 PM
Just2fast
Jan 22, 2006 05:42 PM
whitethunder46
Nov 29, 2005 11:24 AM
cobra4123
Nov 23, 2005 08:10 AM
Bodyman23
Apr 21, 2005 10:10 AM
