fuel pump won't turn on!!!
Old Jan 7, 2007 | 04:34 PM
jareds98gt's Avatar
Default fuel pump won't turn on!!!
my car wont start. the motor turns over but you can't hear the fuel pump turn on, the fuel pump turns on once out of 15 tries. what should i check for?
Old Jan 7, 2007 | 04:36 PM
CCM's Avatar
CCM
Check the fuel cut off switch on the left side inside the trunk behind the tail light.
Old Jan 7, 2007 | 04:40 PM
jareds98gt's Avatar
ya i just checked that, the red button was pressed down, so im assuming its not that.
Old Jan 7, 2007 | 05:17 PM
smg32208's Avatar
99blkgt
check your fuse in your power distribution box on the driver side of hte engine bay right by the battery.
Old Jan 8, 2007 | 07:30 PM
jareds98gt's Avatar
just reset the inertia switch and the pump turns on every time now. still dont know what caused it to stop working.
Old Jan 10, 2007 | 03:53 PM
VSOP's Avatar
40%alc/vol
It probably just was jarred enough to only make contact sometimes.
Its the first thing I check every time, then I check the fuse. If the fuse is good I then get out my meter and test the cutoff switch to be sure its good.
coasterman
Mar 18, 2007 06:22 AM
Mirage775
Feb 27, 2007 01:32 PM
Icefreezen
Dec 27, 2005 04:50 PM
PureStang
Oct 24, 2005 02:10 PM
4.6 Love
Jun 27, 2005 02:33 PM
