not so good sound!
Old Oct 18, 2006 | 10:55 AM
red281gt's Avatar
Default not so good sound!
ok so recently my car has been making this noise when i accelarate around 2000 - 3000 rpms its like a klunk klunk klunk klunk. and now today i stated the car then and then i hear a nother klunk noise right befor the engine starts.
today im going to a shop to have my tie rod replaced and i will have the guy check it out but what do you all think it is.... it cant be denotation cuz i always run 93 octane in it. and the filter is clean and the maf is clean. and i haven't ran it hard for a long time.
Old Oct 18, 2006 | 11:41 AM
red281gt's Avatar
any one have some input
Old Oct 18, 2006 | 01:12 PM
does the sound increase in frequency with the engine rpms or just make a clunk clunk clunk?
could be anything from a bad rod bearing to a loose exhaust. Gotta gimme some more info.
Old Oct 18, 2006 | 07:21 PM
red281gt's Avatar
basically when i accelerate it will make the noise but when the engine is at a steady rpm it doesnt make the sound. it only sometimes makes the clunk when i start the engine up. when i have the clutch engaged and rev the engine it doesn't make the clunking noise. its weird like to day it wasn't doing it that much. at first i thought it was the transmission. and my dad thought its a mount for the engine or trans. he thought that cuz of the "clunk clunk" sound it made when the engine turned over and started.
Old Oct 19, 2006 | 10:05 AM
exhaust hitting something? Check to make sure you have at least 1/4" clearance on all exhaust piping and mufflers to surrounding parts. LMK if you find anything.
Old Oct 23, 2006 | 07:15 AM
red281gt's Avatar
well i looked under there and there is one point where the x pipe is taping the place where the trans crossmember meets the body. i fixed that but i still get the sound when the car is in the low rpm ranges.
Old Oct 23, 2006 | 10:01 AM
could be a loose cat shield, a broken cat, a motor mount going south (causing other stuff to rattle), or just excessive motor shake at low rpms. Does your car have an aggressive-ish idle or does it idle smooth with no real motor shake?
Old Oct 25, 2006 | 09:45 AM
red281gt's Avatar
it idles smooth. and at idle it doent make a noise.
Old Oct 25, 2006 | 12:09 PM
you got me. i give up.
Old Oct 25, 2006 | 12:13 PM
red281gt's Avatar
might it be the tranny or clutch? cuz now it sounded like the clunk sound speeds up as the rpms and mph rises
Old Nov 1, 2006 | 11:01 AM
red281gt's Avatar
had it checked out and they said it's the transmission
Deathdiesel
Nov 16, 2009 03:50 PM
Demetri X
20
Oct 30, 2008 05:28 PM
95STANG
May 4, 2006 09:43 AM
95STANG
Apr 22, 2006 04:10 PM
PureStang
Jul 21, 2005 05:09 PM
