2nd gear scratch - Cobra - diagnosis guys?
Old Sep 18, 2007 | 12:24 PM
Striker 1's Avatar
Default 2nd gear scratch - Cobra - diagnosis guys?
Have a '96 Cobra & when driving normally it's fine but when i do a 1/4 mile run shifting from 1st to 2nd the gear scratches.Does this mean the synchronizer is gone? The car only has 23,000 miles on it so this seems rather odd.When gearing down from 3rd to 2nd its also fine so it's a puzzle.
Old Sep 18, 2007 | 12:32 PM
what rpm are you shifting at?
Old Sep 19, 2007 | 12:11 PM
Striker 1's Avatar
I am shifting at around 6700-6800 rpm when i have this problem.When i shift after the rpm dies down much lower it is fine.
Old Sep 19, 2007 | 12:45 PM
I've heard of a problem in drag cars shifting at high rpm where the clutch is generating a vacuum force and keeping itself either totally or partially engaged regardless of the position of the clutch pedal. Could be similar, could be different. In any case most of those sorts of things should be taken care of by proper clutch adjustment. Have you ever replaced the clutch cable?
Old Sep 19, 2007 | 01:30 PM
Striker 1's Avatar
The cable has never been replaced but it may be a good inexpensive place to start because i really can't believe it's the gear synchroniser that early in the mileage of the car.
Old Sep 19, 2007 | 02:36 PM
While at it, swap out the plastic quadrant for a nice Aluminum piece, such as the one from MM.
Old Sep 20, 2007 | 04:53 AM
Striker 1's Avatar
All depends on the finances at the time but will make enquiries.Thanks
Old Sep 20, 2007 | 08:22 AM
ClemsonStang's Avatar
even the cheap upr setup will be better. it could very well be the synchros, did you buy the car new or used? no one said the origional owner didnt powershift the living hell out of it. atleast the t45 is easier to change then the 3650.
Old Sep 20, 2007 | 08:57 AM
Striker 1's Avatar
I bought the car used so it's quite possible the first owner damaged it.The best thing is probably just to go ahead & order the parts beforehand then have my mechanic rip it down to save downtime.Thanks!
Old Sep 20, 2007 | 01:20 PM
If the problem is only at mega high RPM, let it drop 200 more and go from there. When my tranny was new it was reticent to go into pretty much any gear with the motor spinning over 5K. It's smooth as silk now.
In any case, keep us updated.
Old Sep 21, 2007 | 06:29 AM
Striker 1's Avatar
Will keep you guys in the know as should have some answers very soon.
Many thanks!!!!
cobra1923
Jan 4, 2008 08:31 AM
simbill
Jun 2, 2007 11:41 AM
shad0ws
37
Apr 24, 2006 07:09 PM
blownstang
Mar 31, 2006 10:00 PM
zefjan141985
Aug 18, 2005 02:57 PM
