throwing codes
Old Jul 31, 2007 | 04:21 AM
thundergod's Avatar
Default throwing codes
i need help i am throwing codes po171 -po174 left and right bank lean any ideas on what the cause is and how to fix it thanks.
Old Aug 1, 2007 | 05:29 AM
96TangerineBossGT's Avatar
Check your MAF sensor. I just had that problem with my 95 V6 mustang. I had the same 2 codes and after datalogging the MAF voltage, I found that it was barely even responding at all.
Scott
Old Aug 1, 2007 | 08:16 AM
vacuum leak. also check PCV lines, breather hoses and vacuum lines. listen for a whistling while it idles. that'll help you find it.
Old Aug 1, 2007 | 08:36 AM
^^ Also a possible solution, but I went through all of that myself when I had those 2 codes (no MAF sensor code either) and could not find any leaks at all, and verified with a vacuum gauge, and like I said, there was basically no voltage being sent to the computer and thus, too little fuel was being injected.
The vacuum leak would be likely be the cheaper fix. Check that first, but if you don't find any, go to the MAF sensor.
Scott
Old Aug 2, 2007 | 04:31 AM
thundergod's Avatar
thanks for the help hope to find the problem this weekend.
pxsulliv
Apr 21, 2010 03:00 PM
Leonide
Jan 22, 2009 08:55 PM
PureStang
142
May 24, 2007 05:00 AM
mystics7
Jun 14, 2005 12:16 PM
00gt
Jan 13, 2005 04:26 PM
