shocks
Old Jun 14, 2007 | 01:47 PM
pizzacheff31's Avatar
Default shocks
so im putting in my new shocks and ive followed all the directions, i have screwed them to the car and it says it should tighten to 25 foot LBs of torque. However the nut isnt getting tighter, ive gotten to a point where the actual screw coming out of the shocks spins with the nut as i tighten it. Does this mean im good to go........if not how am i supposed to measure the torque..........and help is welcome
Old Jun 14, 2007 | 02:45 PM
just put it on tight till it still and you will be fine. I never worry about tourqe specs on the shocks and struts just get them tight and go.
Oh and wrong section.. moving to suspension.
Old Jun 14, 2007 | 04:34 PM
Buy yourself an SK torque wrench from Amazon. You use that to tighten things w/ a torque spec. Also, having one is good for maintanence like spark plug changes.
Old Jun 14, 2007 | 08:19 PM
Must See's Avatar
8-2=6
man i just had to replace both rear shocks on my 04 mustang only 18k miles on it. I thought shocks were supposed to last longer than that
Old Jun 16, 2007 | 09:13 AM
you should be able to stick an allen wrench in the shock stem (it should be socketed for it) to hold it still while you cinch down the retaining nut. You need to tighten until it takes a good shove to make any progress or until you see the rubber isolators start to bow out and look like a doughnut more than a bushing.
Old Jun 17, 2007 | 03:40 AM
wearin' that back seat out or sumthin'?
Old Jun 19, 2007 | 08:06 PM
well im pretty happy with the ride im getting now, nice and smooth, i just tighten them as tight as i could, hope it does the trick, im sure it will
madmatt
Jun 1, 2005 10:56 AM
trnin
May 5, 2005 07:46 PM
bluemang417
Apr 13, 2005 08:11 AM
stanger00
Nov 27, 2004 08:00 PM
stanger00
Nov 27, 2004 07:55 PM
