power chip
Old Jun 5, 2007 | 10:29 AM
pizzacheff31's Avatar
Default power chip
so i just bought a +20HP POWER SPEED CHIP FORD MUSTANG 90-95 96-99 for my car off ebay, it was 3 dollars so i fugured it was a win win situation. however im having a hard time figuring out how to install it. MY first step was to locate the antake-air-temerature sensor, which i did. than it says disconect it, which i did. Nows when i got confused "gently pull the tab out and lift the sensor out of the housing" I really dont know what that means. than i have to locate the tiny recepticales found in the IAT wire harness, i didnt know what that ment. Than i was suposed to place one end of the resistor into one slot on the IAT wire harness.
The directions are pretty confusing so i figured u guys were the ones to talk to, let me know if you have done it before, and could explain it to me better thanks
Old Jun 5, 2007 | 10:43 AM
oh no you didnt return that it will hurt your car
Old Jun 5, 2007 | 10:45 AM
Unhappy
seriously why, i had my hopes up so much, in what ways will it hurt it, i guess i should have never trusted that stupid *** who sold it to me, i dont think i can return it now, its to late, lucky it was only 10 bucks
Old Jun 5, 2007 | 12:06 PM
mustangvsix's Avatar
4 point 6
you do realize that resistor you bought you could have got from an electronics store for like .99 at most. Secondly don't install it, it will just screw crap up in the end. Their is a reason a 'real' tuner for our cars cost $300+.
Old Jun 5, 2007 | 12:36 PM
Bwhipple's Avatar
In hibernation
Throw it in the garbage. There is a reason it was 3 dollars. Your cars ECU is a good thing, dont try to fool it.
The "resistor type" chips work by reducing the voltage sent to the ECU by the IAT, or coolant temperature sensors. This tells the ECU that the air coming into the engine is cooler than it actually is (55 degrees most times), the computer adjusts the fuel curves. (how long the injector stays open, and when to open)This means more fuel is pumped into the cylinder, but this does not always mean more power. When you put more fuel into the cylinder, without more air, you will actually lose power. This is because the ECU is getting a false-reading of the temperature and density of the air. This, in-turn, makes the oxygen sensors tell the ECU there is too much fuel. This causes the computer to constantly trying to adjust to the signals, and sees that one or more of them is wrong. It then turns on the MIL or "CHECK ENGINE" light, to tell you, the driver, that there is a problem. So actually, it turns into a waste of time and in some cases may cause you to make expensive repairs.
The "real tuners" $300+ for our cars adjust many things to actually add power. When our cars are shipped from the factory they are tuned for best emmisions mostly. When you tune your car with one of these, its tuned for best power.
Old Jun 5, 2007 | 05:24 PM
just to add to that gr8 analysis it can also lean your fuel and thats also bad
Old Jun 5, 2007 | 07:45 PM
ic, well thanks for the warning, i guess next time i should ask u guys before i go buy it, its my own falt, also thanks for explaining how it works, i had wondered how that little recepor could have done anything good. LUcky i couldnt figure out the directions
thanks
Old Jun 11, 2007 | 06:56 AM
Justin@VMP's Avatar
Don't bother. They don't work.
Old Jul 4, 2007 | 10:46 PM
simbill's Avatar
hahaha,
i bought one of these for my chevy malibu (back in the day, 17 years old 1st car) I was always trying to rice it out and stuff, so this was idiot ricer heaven. I bought one of these on ebay, like him, for like maybe $5. was the worst thing for my car, it musta fried something along the lines because even after removing it a week later the check engine light would not still not turn off! Very bad thing for ANY car.
Old Jul 4, 2007 | 11:47 PM
ok now im getting mad this is the 5th or 6yh dam thread that has been re awkenSTOP PLEASE!!!!!!!
Old Jul 5, 2007 | 04:36 PM
Redrum's Avatar
power chip sucks even i know that
jeds'91_stang
Jun 25, 2007 11:30 PM
New Products
New American Muscle Products
Dec 21, 2006 10:54 PM
05 fastback
Feb 21, 2006 08:22 AM
tanuman
Feb 28, 2005 11:38 PM
