1994 gt help please
Old Jun 4, 2007 | 04:10 PM
94IVGT's Avatar
compcams04
Default 1994 gt help please
1994 gt 5.0l 5sp vortech sc at 8lbs. car runs great without sc,then when i put it on i keep blowing headgaskets. the first two set went when it got hot, the third went today sitting on the dyno just spinnin the wheels up a little, havent even done any pulls. what would be the cause of this??? AFM tells me that it is due to the stock e7 heads having to small deck thickness to handle a sc, but i cant see that being the case. there is countless other sn95s out there running with stock heads and a s/c.
Old Jun 5, 2007 | 09:38 AM
details are a little skinny. what head gaskets are you using? is the correct tq sequence being followed? have the heads been milled? unevenly? they're probably warped now. get a new set.
Old Jun 5, 2007 | 10:29 AM
94IVGT's Avatar
compcams04
they are fel pro graphites this time. the torque sequence was correct and i am using arp studs. the heads have been milled. i checked for flatness with the straight edge and level with the level. both good. as for being warped i havent taken it apart yet but im guessing they wouldnt be due that the car was not yet warm.
Old Jun 5, 2007 | 10:32 AM
I was thinking they may have warped when it overheated and smoked the HG previously.
Old Jun 5, 2007 | 10:37 AM
94IVGT's Avatar
compcams04
the last time i blew the hg was when i had them milled and all that good stuff.
Old Jun 7, 2007 | 09:07 AM
cobra1923's Avatar
they shouldn't blow w/ 8lbs unless you've got too much timing or not enough fuel or octane
Are you running with a BOV?
Old Jun 7, 2007 | 11:17 AM
94IVGT's Avatar
compcams04
yes im running the bov. 'shouldnt' being the main word. timing is set at 10*. and there is plenty of fuel with 255lph intank, trex in line, 42lb injectors, afpr at 40psi.
Old Jun 8, 2007 | 10:39 AM
cobra1923's Avatar
did you drop down a heat range or two with the plugs?
Old Jun 8, 2007 | 10:41 AM
94IVGT's Avatar
compcams04
yes
Old Jun 30, 2008 | 05:35 AM
chuck33's Avatar
use studs instead of head bolts
cobra2616
Apr 2, 2006 08:49 PM
Bimper
Feb 12, 2006 01:34 PM
bikergerm
Jan 29, 2006 07:14 PM
cobra2616
Nov 17, 2005 04:37 PM
eddie
Mar 25, 2005 04:51 PM
