ECU question
Old Feb 24, 2007 | 10:11 AM
CCM's Avatar
CCM
Default ECU question
Apparently I'm gonna need an ECU from a manual transmission car when I switch from the auto to the T45 (at least that's what the shop said). They wanna sell me a SCT 4 bank one with a tune for $300. Can't I just go on eBay and buy an ECU from a 5 speed GT, or will that not work?
Old Feb 24, 2007 | 10:15 AM
you don't need a new ecu. the Auto ecu will need to be tuned but you don't need a new one from a manual car. If you do get one, then a GIZ2 ECU code is one of the better stock programs for your year out of the box.
The only thing that's different is the harness leading into it and the specific stuff for auto-trans controls. Since you are only eliminating parts, the worst you'd get it a CEL and that probably won't even occur. MM&FF guys said in more than one issue in their Q&A section that it's a non-issue... so you don't just have my word for it.
Old Feb 24, 2007 | 10:53 AM
NetChemica's Avatar
It actually depends on the PCM itself. I've seen it first hand where one PCM will work just fine, but when you change the tune in the same exact way on another PCM, it'll still have some quirks in it. Biggest problem I've seen is the hanging RPM, where while you shift, the RPM will stay around 3-5k.
Old Feb 24, 2007 | 11:19 AM
All the ford ECU's for gas engines have the same basic structure. Some use data fields/tables/scalars/arrays/etc... that others don't which supports things like the 03 cobras and 03 gt's using the same basic computer hardware and only changing the tune file and wiring harness.
Can you take my XSH1 tune and slap it on a GIZ2 box... yes but it won't be perfect or possibly even any good at all. this is where having a tuner that knows his business is important.
The rpm issue is purely a tuning refinement issue. Someone should start by reducing the duty cycle value for the IAC. That should allow it to close earlier and more fully and knock the rpms down. You have to be careful with that though or you can cause stalling on closed throttle hard braking.
Old Feb 24, 2007 | 12:02 PM
Why are you getting rid of the auto, and what shop is working on the car?
Old Feb 24, 2007 | 12:21 PM
Wheat's Avatar
+1 for keeping the stock ECU and having it tuned. This is very easily done, flip the software switches, change # of holes for OSS sensor, load in IAC and dashpot settings from a same-year manual trans calibration, and tweak from there. And do yourself a favor, ditch the T45 and put in a 3650 or something else instead.
Old Feb 24, 2007 | 12:25 PM
Do you work at a shop here in VA?
Old Feb 24, 2007 | 12:26 PM
Thats my code. GIZ2!
Old Feb 24, 2007 | 01:22 PM
Wheat's Avatar
Yes. I wasn't going to mention it since I wasn't sure if that would be considered advertising.
Old Feb 24, 2007 | 04:06 PM
What shop?
Old Feb 24, 2007 | 08:53 PM
CCM's Avatar
CCM
Wheat, do you work at Excessive? That's where I'm taking it. They quoted me at $750 (10 hrs. @ $75 an hour I'm guessing) + $300 for a SCT 4-bank and new tune. So obviously I'm trying to skip out on the $300 if I don't have to have it.
Old Feb 24, 2007 | 09:25 PM
I would just get the ECU that you have in their right now reflashed. But you could just go off Ebay and get another one i've seen ppl take that route.
May I ask why the T45 it really wasnt the strongest? If you can find a T3650 I think you'd be better off.
Old Feb 25, 2007 | 09:14 AM
t45 is rated at like 50tq less than the 3650. it's not as strong and the manufacturer admits it. 3650 has a pretty high power capacity for a stock crap 5 speed. The t45 can be built into basically a tko though and that would be even stronger yet than the 3650 and easier to find parts for.
Old Feb 25, 2007 | 07:52 PM
Wheat's Avatar
I work at Springfield Motorsport in Lorton, and have for 12 years. My biggest gripe with the T-45 is the internal shift mechanism, which can take a dump for no apparant reason. Go ahead and keep the stock PCM and have it properly tuned, you know that one day you'll be doing a tune anyway, why also pay for another PCM and key programming?
Old Feb 25, 2007 | 09:22 PM
Okay, I know where that is Wheat. Ive been up to Lloyd's shop.
CCM, Chris @ Excessive told me to my face AFTER he tuned my auto, that he doesnt know **** about them. So Im not sure if hes just assuming youll need a new ECU or what, but it appears that you dont.
Old Feb 26, 2007 | 05:28 PM
Wheat's Avatar
03gtmustang, I guess that's why you now go to Ed Clark? Never met the guy, but he seems to know his stuff. Stop by the next time you go see Lloyd, he does all our machine work and balancing.
Old Feb 26, 2007 | 05:56 PM
Ed definitely knows his ****, real nice guy too. I doubt Ill be up there any time soon, not enough $$$ for any kind of engine work.
Excessive has def had some **** to say about you guys and Lloyd, and pretty much every other shop in the area. All Im going to post about my experience is, Ill never go there again and will never refer anyone to Excessive.
Old Feb 27, 2007 | 05:58 AM
Wheat's Avatar
I know they talk... whatever. I choose not to, most times. However, you should know that Lloyd doesn't do their engines anymore by his choice, not theirs. He got sick of being blamed when a motor burned a piston (must have been the hand cleaner he used before assembly).
Old Feb 27, 2007 | 06:42 AM
Good move on your part. Talking **** about other businesses to customers is not not something you do when trying to run a professional business.
Old Feb 27, 2007 | 07:22 AM
here's a funny in local events that's similar:
tuner 1, buys a CHP built short block, puts it together with a 2v PI top end. The guy that does the assembly leaves the company. A new guy finishes assembly and dynos the car. Guy 1 starts working at a competing shop. The car blows on the dyno. Bad main bearing was blamed on guy1 buy guy2.
CHP was actually at fault. The main was obviously out of spec. Playing the blame game is lame.
Old Feb 27, 2007 | 07:38 AM
Wheat's Avatar
That's the thing about following a **** trail. It's usually smeared, and half the time you wind up stepping in it.
Old Feb 27, 2007 | 07:41 AM
my point exactly.
Old Feb 27, 2007 | 03:15 PM
Chasinsparks's Avatar
CCM, My car is getting the swap tomorrow 27 Feb, I'm going with the 3650 I was told to only change the harness, the only concern I have really is the speed odometer not sure how its going to be affected, its a little different then the old cars seeing as it is electronic, I will let you know the out come it sould be done by friday
Old Feb 27, 2007 | 03:20 PM
  #24
3V2000GT's Avatar
46MONSTER
i had the auto to manual swap and am still using the stock computer, if they need to they can get a hold of www.loganmotorsports.com and Dwayne could probably help with how to tune it.
quik94gt
Aug 5, 2007 08:20 PM
r3dn3ck
Feb 27, 2007 07:14 AM
jamie660
Jul 27, 2006 02:40 PM
DIESEL
Dec 19, 2004 07:19 PM
