forged internals & N/A???
Old Feb 21, 2007 | 04:42 PM
Default forged internals & N/A???
Noob question.....
Forged internals make a stronger engine are, but are there any advantages to having forged internals and staying N/A?
I'm assuming that if I forged my internals the compression would more than likely drop from 10:1:1 to about 8:5:1 (just a guess) and I would lose power, but is there a way to forge the internals and safely up the compression past the 10:1:1 ratio and gain power?
Old Feb 21, 2007 | 05:19 PM
Yes, but then you run too much and youll need race gas.
Old Feb 21, 2007 | 05:21 PM
3V2000GT's Avatar
46MONSTER
if you forge your internals you wont lower compression. Compression depends on what pistons you have, lower the compression= less power better for turbo supercharged cars, higher compression= more power NA. I have forged internals and Im NA, I have the highest compression without having to use race gas
forged internals = good less to worry about, your crank is already forged
silverstang04's Avatar
Not a pro at this but I think you would want to go with high compression pistons. Not really sure, the pros will be here in a minute.
Old Feb 21, 2007 | 05:24 PM
Oh ok, that makes sense. What compression are you able to run on your car without race gas?
Old Feb 21, 2007 | 07:04 PM
Usually the OEMs won't put more than 11:1 in their cars to run on pump gas so that is probably a good limit to abide by.
Old Feb 21, 2007 | 09:29 PM
3V2000GT's Avatar
46MONSTER
im 100% sure but 12:1 but i do know its real high
Old Feb 22, 2007 | 06:53 AM
This question though is tough to answer since it also depends on the cam. If you have a profile w/ more overlap, then you can get away w/ more compression.
Old Feb 22, 2007 | 07:20 AM
CompOrngGT's Avatar
yes, some custom cams are designed to bleed some compession, some just loose some due to overlap. 11:1 is a good safe limit, but you'll always have to run 93 after that. if you're staying NA, or small shot nitrous, you can go with a nice lightweight I beam rod, instead of an H beam.
Old Feb 22, 2007 | 12:03 PM
forged goodies in the bottom end are just there to add strength. it will allow you to get your car up to the limit of its potential without as much risk of grenading it thanks to a weak link in the rotating assembly. It's not insurance it's just risk avoidance. Any power adder can be turned up on a motor properly built with forged parts far higher than it can on a motor built with cast parts. Our stock rods are forged... they're just not rated for the kind of power most guys will want to shove at them. They are forged from powdered metal which causes each grain of metal to weld to all its neighbors. Too bad they're not rated for nearly as much power as we want. In a more stout version they would be a great option.
My motor will be at 10.2-10.5:1 which is about as tall as you should go on california 91 octane gas. 11:1 would require a bit of adjustment to the tune at the expense of power so that a bad tank of gas wouldn't be a potential engine killer and it would make it very difficult to pass the sniffer.
If you can afford a forged shortblock... do it. There's no reason not to other than expense. Then we can slap a nitrous kit on your ride.
V6_Mustang_Power
May 26, 2008 01:10 PM
Rabbit
Sep 1, 2006 11:58 AM
the gillz
May 31, 2006 01:50 PM
MustangGTuning96
Feb 28, 2005 02:55 PM
