Need Motor Oil opinion!
Old Feb 16, 2007 | 02:53 PM
stngmn96's Avatar
Default Need Motor Oil opinion!
Hey all!
I have been meaning to ask since I had my motor built from the stock 96 to a full PI swap and flat top forged piston set up, if the stock 5w-20 motor oil should be used? I used to use 5w-30 no matter what since the 5w-20 was hit or miss on brand availability. My question is this; should I use a heavier motor oil weight since I am running forged pistons and high compression? I haven't found anyone to really tell me if this aspect of things should change. I only use full synthetics, but would like some input on this or what the rule of thumb is? Thanks.
Old Feb 16, 2007 | 03:26 PM
the compression on my mach is 10.1:1 and I use the recommended 5w-20 with no problems. I don't have forged internals so I don't know that aspect of it.
Old Feb 16, 2007 | 03:48 PM
stngmn96's Avatar
It seems to me thus far even with the 5w-30 in it, the forged parts tend to clatter awhile until they are sufficiently warmed up and that may take awhile. I am just hoping to make sure all the right parts stay lubed and to ensure the internals are coated with the right stuff.
Old Feb 16, 2007 | 03:57 PM
Personally, I'd say that in the winter, stick w/ th 5W20 but in the summer, go with 5W30. Unless you are doing some serious high rpm racing, than the slightly thicker 5W30 won't affect anything.
Old Feb 16, 2007 | 04:11 PM
I'm switching to 5w30 next oil change due to some head noise. And i'm getting close to 93k miles so I want some extra protection.
Old Feb 16, 2007 | 04:19 PM
depends on the clearances in your motor. Typically a modular engine is a pretty tightly put together beast if it's gunna live very long between teardowns so the clearances will still be mostly the same as stock... tight. If your ring gaps are set of for NA then you should have no serious issues with 5w-30 oil of any reputable brand. Yes you may have a little bit of oil burn as the pistons swell but we're talking miniscule amounts and done by warm up. I would not be concerned.
Othic
May 16, 2006 08:40 PM
Oct 11, 2005 11:49 AM
Icefreezen
Aug 27, 2005 09:22 AM
StangMan04
Jul 30, 2005 05:39 PM
Erik
Feb 15, 2005 06:19 AM
