cam question
Old Feb 15, 2007 | 09:20 AM
1982 mustang 5.0's Avatar
Default cam question
ok so soon im going to start to rebuild my engine and i wanna put a cam in it but i dont know much about cams so what would u guys recomend
Old Feb 15, 2007 | 01:00 PM
ClemsonStang's Avatar
call a cam company of your choice.
need much more details of your combo. tell us more about the combo and what you want to do. just need a ton more info.
best off to call a few cam companies and get their advice
stay away from alphabet cams... ive got one in my car cause its cheap, but they are 20 year old technology.
Old Feb 15, 2007 | 02:20 PM
Couldnt of said it better myself. You cant just go what cam do i need? its alot more complex then that. You need to macth the cam to your intake manifold and heads flow ability. You need ot get a cam that works well with your rear end gears and or convertor stall speed. There are a few things you need to think of before you choose. Also if your gonna stay n/a, sprayed,or forced induction.
So start reading online about cams or call the companies and be sure of your final goal with the car. A cam should be one of the later mods you do if you ask me.
Old Feb 15, 2007 | 04:41 PM
well im going to be using 351 heads and i have 3.73 gears going to put on some dome shaped pistons and roller rockers and im going to stay n/a for a long time i just want to put in a cam since im going to be taking the motor apart i dont want to go back later and tear everything apart again
Old Feb 15, 2007 | 05:09 PM
call comp cams and talk to them best thing you can do. There tech lines are awsome and will help pick a cam that makes the most power and works best.
Old Feb 15, 2007 | 06:11 PM
what intake? i would assume carb? where do you want your power band? are you going to run upgraded springs, behive springs, hardend push rods.
Old Feb 23, 2007 | 11:53 AM
domed pistons will limit your cam options in a big way. I'd start thinking about fly-cut flat tops. Those will put the compression in a useable zone and allow you to run a nice fat cam.
redlinestang07
Aug 13, 2008 01:37 PM
OFFdutyHERO
Jan 2, 2006 06:21 PM
NoKturnaL
Dec 28, 2004 12:05 PM
Jeremy
Dec 20, 2004 10:54 AM
79Fox
Dec 13, 2004 05:07 PM
