parking brake light
Old Feb 2, 2007 | 09:38 PM
mustngspd's Avatar
Default parking brake light
when i turned my car on this afternoon the parking brake light came on, and then it would turn on and off frequently when i was driving to work, and then on my way home from work it just stayed on. whats causing the parking brake light to turn on?
Old Feb 2, 2007 | 10:18 PM
Are you talking about the red light on the dash????
Probably low break fluid.
Old Feb 2, 2007 | 10:21 PM
Another possibility if the dash light is on is that considering the cold weather lately, your brake lines could have froze. The same thing happens to my dad's F-150. Just make sure your brakes are disengaged by engaging/disengaging it until the light goes away.
Old Feb 3, 2007 | 08:35 AM
flyinfox's Avatar
go on3
most likley low brake fluid becouse you brakes have worn down just add a little fluid will go right away
Old Feb 3, 2007 | 10:27 AM
mustngspd's Avatar
is it ok to mix different brands of brake fluid or do i have to bleed the brake system and then put the new fluid in?
Old Feb 3, 2007 | 10:53 AM
flyinfox's Avatar
go on3
it is ok do mix diffrent brands but not diffrent dot like dot 3 and dot 4 don't mix
Old Feb 3, 2007 | 11:00 AM
mustngspd's Avatar
i bought some high performance brake fluid that exceeds dot 3 and dot 4 and is compatible with conventional brake fluid, i dont think the brake fluid has been changed since the car was manufactured in 98, so is it ok to mix with that or should i just go ahead and replace the fluid
Old Feb 3, 2007 | 01:21 PM
DOT 3 and 4 do mix, it's DOT 5 that you can't mix with the others since it's silicone based rather than glycol based.
Old Feb 4, 2007 | 08:42 AM
mustngspd's Avatar
i added more brake fluid and its filled to the max line but my parking brake light in the dash is still on.
Old Feb 4, 2007 | 09:15 AM
Check your parking brake. If you leave it out in the cold, water in the cable freezes preventing it from disengaging. If it doesn't go away w/ repeditive enaging/disengaging to break the freeze, try readjusting your parking brake.
Old Feb 4, 2007 | 09:23 AM
mustngspd's Avatar
how do i readjust my parking brake?
Old Feb 4, 2007 | 10:43 AM
That I can't help you with since I only know how to do it on my car since it's self-adjusting. I believe you do it at the equailer bar though, where the 2 cables meet before the handle.
IceMan
May 9, 2007 07:15 AM
GT Ninja
Oct 2, 2006 05:48 AM
frostybrew
Aug 27, 2006 06:33 PM
B-rett
Dec 23, 2005 08:05 AM
pneon99
Aug 24, 2005 04:22 PM
