has anyone done a gear swap on their own?
Old Jan 29, 2007 | 02:01 PM
triggertap79's Avatar
Default has anyone done a gear swap on their own?
....and had success with it? I know everyone says you're better off to have an experienced mechanic do it, but I'm curious to see if any first timers have successfully done one on their own. How hard is it?
Old Jan 29, 2007 | 05:59 PM
Yes i did it in my 99 f150 it was a pain in the ***. But i will be doing it in my car aswell. YOu do need a dial indicator which costs around 100-180bucks for the tools your almost at the cost of a pro install. Think about it.
Old Jan 29, 2007 | 06:04 PM
didnt you botch that....
Old Jan 29, 2007 | 10:33 PM
jadartt's Avatar
I just did mine 2 weekends ago. There is absolutely no sound from the rear end at all. It is just as quiet as the factory gears. I went with 4.10's.
As stated you need a dial indicator. I measured my backlash before removal and upon reinstall just adjusted to that same measurement. Backlash is that little bit of slop (0.008) that you get between the ring gear and the pinion gear.
I bought FRPP gears which I believe are the best for the DIY crowd since the are factory Ford gears and fit as such. I reused the original shim under the pinion gear and the backlash measurements came out exact. The toughest part is crushing that darned crush sleeve. Good air tools are a must.
Old Jan 30, 2007 | 04:48 AM
the shop i paid 200bucks screwed my first set of 4.10's up in my old truck.
Old Jan 30, 2007 | 07:31 AM
ClemsonStang's Avatar
its not too bad to do yourself. but 10,000 miles from now and some good hard launches and they will be alittle noisy. if your not scared go for it! i did it for school, and to be honest its just a pain in the *** trying to get all the right shims and get it all set up "right". with some patience and practice you really develop a touch for it, kinda like transmission work.
Old Jan 30, 2007 | 09:41 AM
Thats what I thought....well if you do a good job on yours i'll pay you to redo mine when I get a new diff.....dont ask what I did to it.
Old Jan 30, 2007 | 11:42 AM
Most of the really good wrenches I know still go to a pro to have gears set up. The guys you want doing it are the ones that can set bearing pre-load by feel. Doing it yourself without understanding what exactly to look for in a paint test is asking for trouble down the road.
Get thee to a pro. It's worth it to make sure the least often maintained part of your car is set up right to begin with.
Old Jan 30, 2007 | 02:29 PM
I will more than likely end up taking it to a pro to have the gears done.
Does anyone know where I can find a good write-up on a gear install just to see what it entails? Thanks for the feedback.
Old Jan 30, 2007 | 02:41 PM
THeres a reason there is a sticky on this..
https://mustangboards.com/general-te...ar-thread.html
Old Jan 30, 2007 | 03:15 PM
I've read the sticky. I agree, chances are I would end up ****ing something up if I did it myself. I just wanted to see if anybody has done one themselves and got it right. Thanks for your help anyways.
Old Jan 30, 2007 | 04:00 PM
mustang rears are alittle differant, but this is from someone i know and trust...
http://www.keliente.com/gears.htm
Old Jan 30, 2007 | 09:21 PM
jadartt's Avatar
Am I really the only one who has successfully done this? Backlash backlash backlash, get it right and your in.
Ok Ok, another difficult part is if you don't get the shims correct the first time you have to remove the pinion bearing possibly ruining it several times before you get the backlash set right.
take it to a pro.
Old Jan 31, 2007 | 07:00 AM
having a press is a must also or you wont be getting the bearing onto the pinon gear. But it takes time and you might have to pull the posi out a good number of times before you get the correct meshing on the gears (wear pattern).
Old Jan 31, 2007 | 07:48 AM
A press isn't required. A nice hot-rodder's trick is to heat the bearing and cool the pinion enough so it just slides on. Of course if you screw up the shims or placement, you will need a press to take it off. Also, there are kits available consisting of bearings that have been honed enough to allow you to slide them on so it's easier to check backlash, etc. However, those bearings aren't to be used as bearings, just to check your measurements.
Oct 9, 2007 10:10 PM
rebelyell
Feb 3, 2007 02:30 AM
Thomas
32
Dec 15, 2006 06:19 PM
95STANG
Jun 5, 2006 10:00 AM
4.6 Love
Jan 4, 2006 10:46 AM
