UH! Not good.....
Old Jan 29, 2007 | 12:06 PM
red281gt's Avatar
Exclamation UH! Not good.....
Ok so what would make your oil turn colors? few weeks ago it was normal color it would be when getting close to changeing time but now (500miles b4 due for change) i check it and the oil cap has brownish tan gunk on the cap as does the dip stick(not as much brown color). some of it was in the valve covers crossover tube that gos to the intake to. WTF! Would cause this.?
Old Jan 29, 2007 | 12:46 PM
sounds like you have some sort of leak. head gasket maybe. check your coolant levels
Old Jan 29, 2007 | 01:03 PM
Drain the oil and let it sit for a while in the drain pan. If you had a leak w/ the coolant, it will form a layer on top of the oil.
Old Jan 29, 2007 | 01:05 PM
red281gt's Avatar
mm kay. damn i hope not tho
Old Jan 29, 2007 | 05:58 PM
does it look like a milkshake kinda? if so head gasket or gaskets have blown. Also is it blowing some lite or heavy white smoke?
Old Jan 29, 2007 | 06:22 PM
a lot of times, if you have a blown head gasket... you will see residue on the cap from coolant.
"milkshake" is also a prime indication...
Old Jan 30, 2007 | 05:31 AM
red281gt's Avatar
. i think it is cuz this morning there was a sweet smell in the exhaust gas. UGH!
Old Jan 30, 2007 | 05:42 AM
mcmmotorsports's Avatar
Resident Mental Patient
What does the oil on your dipstick look like?
**edit*(re-read first post)
Drain the oil as said above and make sure there is no antifreeze in there. If so, headgasket.
Old Jan 30, 2007 | 09:30 AM
smells like surup doesnt it? your got yourself blown head gaskets my freind. Time to get some PI heads.
Old Jan 30, 2007 | 11:37 AM
HG is officially blown. No way to get the sweet smell and the slimy choco-shake goo in the oil but to blow the HG. You're burning coolant as well so you're at risk for getting a hydraulic lock on a cylinder and completely smoking the motor via catastrophic self-disassembly.
Pull your plugs and look for the really bad looking one. That'll tell you which gasket it was so you don't have to replace both (but you still should replace both). Since you've got coolant in the cylinders you're also at risk for blowing up your radiator so no startie until fixie.
Good luck. It's often cheaper to find a good used longblock and just swap it in. HG jobs are about 800-1000 or more around here.
Old Jan 30, 2007 | 02:59 PM
the gillz's Avatar
Bruce Leeroy
maybe someone put sugar in your tank and it turned the oil into caramel. happended to me once. bastards
Old Jan 30, 2007 | 05:15 PM
just buy a used pi motor from someone. you can find them locally around here. I got one with 45,000 miles on it for $500 TB to oil pan. While your in there put on some headers if you dont already have them, and a moroso oil pan.
Old Jan 30, 2007 | 05:30 PM
I can tell you that ford will charge you 11.x hours for both head gaskets and thats labor alone. you can expect to pay about 1,100 for that. the gaskets are cheap. like redneck said, its time for heads. could be a warped head from low coolant or a bad gasket. last thing you want to do is do the gasket job and find out you have a warped head or both are warped.
Old Jan 31, 2007 | 04:59 AM
red281gt's Avatar
well monday my mechanic (ex-ford tech) is going to do a compression test and all that business and he is going to check if the heads are cracked or if the block is cracked, so right now im driveing my girlfriends beater around
Old Jan 31, 2007 | 05:01 AM
red281gt's Avatar
Oh and someone around here is gettin ready to sell a 2000 gt longblock with 30K on it for $1300 not too bad for being around nova where everything costs an arm-n-a-leg
Old Jan 31, 2007 | 04:29 PM
eventer289's Avatar
The chocolate milkshake on the oil cap is normal. It is just moisture that has evaporated onto the cap that is caused by short start and stop drives. I have the same thing with my car. But, I do not (knock on wood) have the same color on my dipstick. Like everyone has said above, you most likely have a blown headgasket. If you continue to drive around with it like that you will shell your motor.
Old Jan 31, 2007 | 07:58 PM
red281gt's Avatar
haha that's why im not drivein it now even tho if i did "shell" the engine it would just give me a reason to get a built engine and make this Bit** a weekend warrior.
Old Jan 31, 2007 | 10:14 PM
I would either build the motor or replace with a used long block. I paid $700 for mine and it had 8,000 miles on it. I also had to buy a few odds and ends like valve covers, so don't forget **** like that.
Old Feb 1, 2007 | 06:00 AM
red281gt's Avatar
I wish I was rich!
Old Feb 1, 2007 | 06:33 PM
eventer289's Avatar
Have you never heard that before? Just wondering why there are quotes around it.
r3dn3ck
Aug 27, 2010 10:07 PM
whitethunder46
Oct 14, 2006 06:55 AM
JoeMacDJ
Nov 11, 2005 08:25 AM
Jack The Ripper
Jul 22, 2005 11:59 PM
