The Reference Section Just installed a new part on your car? Write up a How-To and post it here.
The How to paint your Calipers
Old Feb 17, 2007 | 06:28 PM
Default The How to paint your Calipers
Ok Today I just completed painting my break calipers.
I wanted to show everyone else how to do it also.
Step one remove the center caps from your wheels.
Old Feb 17, 2007 | 06:29 PM
What a great tutorial, haha jk.
Old Feb 17, 2007 | 06:32 PM
Step 2
Un torque the bolts but do not remove. The use a jack to lift your car just enough for the tire to be off the ground. Then revome the loose bolts and remove tire.
it will look like this
give me some time now first one of ever done
Old Feb 17, 2007 | 06:36 PM
step 3
assuming you already bought a caliper paint kit get that out follow directions. I went with dupli color. spray and clean surface with the cleaner that is in the kit and scrub of dirt and grimeName:  2004_0210CalipersPT10010-1.jpg
Old Feb 17, 2007 | 06:41 PM
step 4
wait untill the all dirt is gone and let dry for 10 min.
then mix your paint up that is provided and paint a lite coat on caliper.
Old Feb 17, 2007 | 06:44 PM
step five
allow first coat to dry for 20 min then apply a second or third if youd like.
and when done allow to dry angin and put the tire on again and re do all bolts and re torque and your done.
I will post more picture later.
hope this was informal for those of you who will do this in the future.
Old Feb 17, 2007 | 08:41 PM
A suggestion. Take off the calipers and then paint.
Old Feb 17, 2007 | 10:53 PM
not worth my time it only took 20 min to do each one.
Old Feb 19, 2007 | 04:30 PM
Stan's Avatar
Beantown Stang
did you do all 4? some pics with rims on would be nice..
Old Feb 19, 2007 | 04:41 PM
Must See's Avatar
8-2=6
I want to paint mine, i just need some jack stands and one of those lifts thingys as well as a torque wrench. Im sure i could get some @ walmart for real cheap.
Old Feb 19, 2007 | 07:34 PM
yeah i did all 4 ill get those pics up for you as soon as a can get my cam back from my dad he has it at work
Old Feb 19, 2007 | 07:36 PM
i didnt use jack stands. just used a jack lifted it did one at a time.
but i had to go to a shop and have them un torque them.
but i ended up buying a torque wrench for 15 bucks well worth it.
and it would look real good with your red paint
Old Feb 19, 2007 | 07:48 PM
Must See's Avatar
8-2=6
I think this will be one of my summer projects. An easy and relativly cheap comsmetic mod.
Old Feb 19, 2007 | 07:52 PM
Must See's Avatar
8-2=6
Old Feb 20, 2007 | 01:20 PM
there is no way all that is under 30 my jack alone cost me 30 and its not the nice push jacks its the hand turning one
Old Feb 20, 2007 | 02:41 PM
Pilks's Avatar
so any pictures of the finished product
Old Feb 20, 2007 | 02:49 PM
Stan's Avatar
Beantown Stang
thats about right i got my craftsman jack and 2 jackstands for $50
Old Feb 20, 2007 | 03:14 PM
here is one w/o the tire on i have to get the one with the tire uploaded
these are the back calipers the front look much better i get thoses up to
Old Feb 23, 2007 | 10:21 PM
NetChemica's Avatar
What kind is it? I sure hope it's the beam type where the handle itself flexes. Even then that's quite cheap. A decent micrometer type one will set you back about $100. I would only trust something like that on lugnuts, or suspension/brakes (something where accuracy isn't that important).
Old Feb 24, 2007 | 06:15 PM
jblueguy's Avatar
Considering the weather that those calipers will take, I'd be suprised if that paint lasted through the summer. I priced getting my calipers powder coated and it would cost me about 25 bucks each. The big problem there is the calipers have to be removed from the car which means bleeding the entire brake system. However, the powder coating would last for years. That is how the colored calipers sold by brembo, ford racing, etc. are done. The paint is actually baked into the metal. The calipers look good now, but I'd be interested to know how long it lasts.
Old Feb 25, 2007 | 03:24 PM
Its a Gorila Power Wrench
Old Feb 25, 2007 | 03:26 PM
they can take up to 500 deg of heat. they will be fine. its dupli color they are the best
Old Feb 26, 2007 | 05:37 PM
jblueguy's Avatar
Please check back in with this, because I'd much rather do that than disassemble my entire brake system.
Old Feb 26, 2007 | 07:03 PM
if your refering to the 500 degree than yes its true.
Old Feb 26, 2007 | 07:39 PM
jblueguy's Avatar
No, I mean check back in at the end of the summer to let us know if the paint flaked off and powder coating is necessary, or if the less expensive paint will do.
Old Feb 26, 2007 | 08:11 PM
if you want to wait that long ok. see u in summer time.
Old Apr 21, 2007 | 01:57 PM
Old thread but How are they looking two months later?
Old Apr 21, 2007 | 06:15 PM
haha on sunday (tomarrow) I will take pics to show how they are
