chip vs programmer II ! was just way too long
Old Jan 23, 2007 | 06:24 PM
sugnyte69's Avatar
yellow fever
Default chip vs programmer II ! was just way too long
so what if you're thinking of running a tuner and a programmer i have a sct and i ordered a programmer i can run them both cant i?? if not which would you use
Old Jan 23, 2007 | 06:42 PM
nope, can only run one.
Old Jan 23, 2007 | 06:45 PM
sugnyte69's Avatar
yellow fever
that sucks ill probably just put the other on ebay why cant you run both what happens
Old Jan 23, 2007 | 07:02 PM
they reprogram your car computer to make changes. You cant use two when one already does the entire job.
its like putting two rims on one axle.
Old Jan 23, 2007 | 08:04 PM
sugnyte69's Avatar
yellow fever
oo ok
Old Jan 24, 2007 | 09:28 AM
What, you've never put to rims on one axle before..ha ha
Old Jan 24, 2007 | 10:48 AM
dually's man... there's a case for every bizarre idea. Even two wheels on one side of an axle.
I had that decision to make just recently and I figured that the handheld makes it SOOOO much easier to get a new tune that it was the only logical choice. Chips have to be pulled from the ECU each time a tune is flashed onto them so they're less than totally convenient.
A handheld tuner replaces the tune on your ECU with a new one entirely. The chip method uses the data port on the ECU to piggyback a new tune over the top of your stock tune which makes the stock tune invisible until the chip is removed. It is not possible to use both in any conventional manner.
Old Jan 24, 2007 | 02:19 PM
Why the hell would you want to use both anyways?
110
Mar 17, 2023 07:24 AM
jeds'91_stang
Jun 25, 2007 11:30 PM
chado31
May 22, 2007 01:33 PM
SpinMedia
Oct 22, 2006 07:09 PM
