Drag Racing! Discussions on drag racing, using the tree and techniques for improving your performance at the track
New to drag racing, i need a little advice...
Old Jan 6, 2007 | 08:50 PM
CoryTACP's Avatar
Default New to drag racing, i need a little advice...
I want to add some suspension parts to my rear end to make it hook a little better. I've read about getting LCA and UCA's...what exactly do these do for it? and since I'll be buying them seperatly which one should I get first? I'm going to get some 4.10s for the rear end eventually but I figured I would get some parts to make me grip better before I get them. any advice would be appreciated. BTW, i have a 2000 gt 5-speed. stock except a JLT ram air and BBK lowering springs.
Old Jan 7, 2007 | 01:40 AM
Control arms prevent wheel hop and allow the car to launch more straight. The think the uppers address the hop issue.
If you are not getting wheel hop, I am not sure if you really gain much by adding them.
As far as which one first upper or lower, I don't like to do the same work twice. I did both at the same time which lowered labor costs.
I went with UPR. You can get both upper and lowers for about $200 and they are probably the best, cheaper control arms on the market. Lots of fast guys running these.
Old Jan 7, 2007 | 06:39 PM
CoryTACP's Avatar
So what would be some suggestions that I do to the suspension to make it hook up better? Would it be better to just get some drag radials and go from there?
Old Jan 7, 2007 | 06:49 PM
lower get rid of the hop, and uppers are used to change the pinon angle to get more traction by aiming the pinon slightly down.
stage2roush2002
Apr 10, 2008 09:47 AM
CoryTACP
Drag Racing!
Feb 20, 2008 11:05 AM
whitethunder46
Jan 23, 2007 07:44 AM
03BullittClone
Jan 7, 2005 05:33 PM
tlh03122001
Nov 14, 2004 11:19 PM
