Fuel Filter
Old Jan 4, 2007 | 06:57 PM
03_GT's Avatar
Smoke Tires....Not Drugs.
Default Fuel Filter
What is the easiest way to change the fuel filter on a 03 GT?
Old Jan 4, 2007 | 07:12 PM
Very easy thing to do.
1. Take out the fuse for the fuel pump and let the car run until it dies. You can skip this but you will end up w/ a ton of gas on you if you do.
2. Jack up the rear.
3. Using a fuel-line disconnect tool, disconnect the fuel lines.
4. Loosen the hose clamp and pop the filter off.
5. Repeat steps backwards (the disconnect tool won't be needed) to install the new one.
Old Jan 4, 2007 | 07:17 PM
03_GT's Avatar
Can i go to any auto parts store and get this tool?
Old Jan 4, 2007 | 07:18 PM
yes
Old Jan 4, 2007 | 07:31 PM
03_GT's Avatar
Ok cool! Thanks Guys!
Old Jan 4, 2007 | 07:36 PM
Old Jan 5, 2007 | 08:46 AM
I did a write up on this a while back....the directions are like the bullitt archives, but I did a few things differently to help with gas leaking.
https://mustangboards.com/the-refere...el-filter.html
Old Jan 5, 2007 | 02:16 PM
jareds98gt's Avatar
im in the process of changing my fuel filter and i can't get the 5/16 tool on the filter. its supposed to connect on the filter and then push the fuel line off of the filter right??? help!!!!
Old Jan 5, 2007 | 02:39 PM
What type of fuel line disconnect tool do you have? There are a few different types of tools. These are the ones I used. I just slid them in and then pulled the line out.
http://www.pelicanparts.com/catalog/...CAT405_pg4.htm
Old Jan 5, 2007 | 06:38 PM
jareds98gt's Avatar
i got basically the same thing. i finally figured it out. i just couldn't get the tool on the filter. it was easy from there.
coasterman
Mar 18, 2007 06:22 AM
The Reference Section
Nov 18, 2006 05:26 PM
Justin99gtconv
Mar 25, 2006 06:24 AM
Icefreezen
40
Jan 21, 2006 05:42 PM
03gtmustang
Dec 24, 2005 08:12 AM
