Rear End
Old Dec 27, 2006 | 01:43 PM
Chasinsparks's Avatar
Default Rear End
I have an 04 Gt I had 4:10 Gears installed and shortly after a horrible grind sent the car back to the shop they fix the problem now just over a year later I have a loud humming / whine sound there is no visible sign of fluid leak is there anything else it could be or should being just over a year should the gears be going
Old Dec 27, 2006 | 02:11 PM
Gears were installed wrong, might want to consider bringing the car to another shop. You might also have to buy new gears if these are messed up. Either way, Id have a different shop install new bushings etc., http://www.americanmuscle.com/rearendrebuild.html and reinstall the gears and make sure backlash, ect., is set up correctly.
Where are you located?
Old Dec 27, 2006 | 02:16 PM
if you do a lot of burnouts (particularly donuts) then you may have a little play in the clutch pack from heavy wear which will allow the gears to move out of spec and howl. You may have also compressed the crush sleeve from some kind of shock loading and your gears are out of spec due to that. Could also be a bearing going out.
I'd take it back and tell em that your gears are howling and you think their setup may have something to do with it. Ask them to figure out if it's their work of if you blew an axle bearing or something like that. In any event, try not to drive it too much till you have it fixed. You don't want to shoot the whole works out the inspection cover.
Old Dec 27, 2006 | 02:53 PM
Default Thanks
I don't do burnouts tires are to expensive, I had them installed at Steen Racing got a call into Jason they have done them both times hopefully the get me on the road soon
Old Dec 27, 2006 | 03:38 PM
Steen has a good rep around here. I bet they'll take good care of you. Let us know how it comes out.
Old Dec 27, 2006 | 04:38 PM
Damn, Steen has a good rep all the way out in Cali? They have a good rep here on the east coast, like r3dn3ck said, they should get it taken care of.
Old Dec 29, 2006 | 08:40 AM
actually meant on this board...
Some of the more... picky... people on this board pick steen to do their work. Says quicte a bit.
Old Dec 29, 2006 | 04:31 PM
Oh, yes, Steen is a good shop. Thats where Randy gets all his stuff done along with Jim Travers, that right there says enough.
Old Dec 29, 2006 | 04:39 PM
Lunati's Avatar
Whats that Whining Noise?
+1. Great shop and awsome ppl. They will get it fix.
dmkx3
Mar 8, 2005 03:56 PM
Erik
Jan 30, 2005 11:30 PM
Erik
Jan 22, 2005 05:55 PM
Mikes04stang
Jan 20, 2005 04:10 PM
SNY95
Dec 25, 2004 01:26 AM
