Cobra rear brakes?
Old Dec 4, 2006 | 02:38 PM
Default Cobra rear brakes?
My rear brakes have started making a grinding sound when I slow down and come to a stop. I dont know why, they arent all that old. I figured I would just throw on a cobra brake kit if theres not too much involved. Where can I find a kit to convert my GT rear brakes to the cobra? I know where to get the rotors and pads, but I cant find the bracket to move the stock caliper. Or do they use different calipers? I was planning on fixing it tomorrow, but I dont really want to throw on a new set of GT rotors and pads.
Old Dec 4, 2006 | 04:10 PM
you have to pull the axles, get a conversion FRPP kit which is 200 bucks, then get the brake kit.
Keep your stock stuff, the upgrade isnt worth it for the rear.
Old Dec 4, 2006 | 04:11 PM
the rear is simply bling unless you do some hardcore road racing the cooling effect they have isnt worth it. And more then likly your pads are toast thus the noise, get new pads and call it a day.
Old Dec 4, 2006 | 07:31 PM
Don't forget that when you replace the pads, to do the job right, get your rotors resurfaced or buy new ones.
Old Dec 4, 2006 | 07:33 PM
I agree with Dustin, just get new pads. I dont believe you need to get your pads resurfaced just because you replace your pads. Someone correct me if Im wrong.
However, one thing I do know is that youll have to push the piston in when getting new pads. For the rear, you need to use needle nose pliers and twist the piston while you push it in. Then you have to make sure the piston notches are lined up correctly.
Im too lazy to explain it, so heres a post on modularfords I found a couple weeks ago, http://www.modularfords.com/forums/722257-post2.html And yes that is the correct way to line it up, Ive heard it from more then just that guy.
Old Dec 4, 2006 | 07:37 PM
The rotors (not the pads) need to be resurfaced otherwise the brakes will squeak.
Old Dec 4, 2006 | 07:38 PM
Sorry I meant rotors.
You SHOULD have your rotors resurfaced everytime pads are replaced. If you just bring rotors yourself into a dealership, they should resurface them for pretty cheap, like 15 bucks.
Old Dec 4, 2006 | 07:43 PM
Alright, thanks guys. In that case, ask Randy for some stock pads and bring your rotors somewhere to get resurfaced.
Old Dec 4, 2006 | 08:14 PM
yes I know about resurfacing my rotors. If I were to go with some stock size rotors I want it to be at least a set of slotted new ones. I am looking to be different. I want to have the actual cobra rear setup just cause many people dont have them. Also Im looking at wheels/tires soon and I want to have something for show.
Old Dec 4, 2006 | 08:41 PM
geez, over 400$ just for the rear kit? Maybe ill have to wait. I wanna start putting all me serious cash into the new engine.
Old Dec 5, 2006 | 05:02 AM
From what I hear, slotted is just for looks and the only thing it will give you is a ton more of brake dust.
Old Dec 5, 2006 | 11:10 AM
that's about the fact of the matter. Modern pads don't outgas so slotting does keep the pads clean and breaks up glazing but that's all. They're only marginally dustier than plain faced. I use plain faced Baer Eradispeeds. Best rotor I've had on a daily driver to date.
Old Dec 5, 2006 | 12:09 PM
I would only resurface the rotor if its glazed or warped. Otherwise no need to spend the money on it.
Old Dec 5, 2006 | 02:08 PM
for bling value steeda markets a 13" rear brake kit that looks really cool. It uses a bracket to relocate the caliper for a 13" rotor in the back. Makes pulling the axles a thing of the past. If you're going to bother, that's a helluva route to go.
If you upgrade the rear brakes make sure to choose the right pad. I like EBC green for cars with cobra front brakes and OEM pads for cars with stock GT/v6 front brakes. It maintains a better balance if you choose carefully.
Old Dec 5, 2006 | 05:44 PM
I am going to put some nice pads on it and have the rotors turned for now. I will get the Baer 13 inch kit when I get some more money. I think its only $250.
Deathdiesel
Mar 31, 2010 08:22 PM
95V8Conversion
Nov 6, 2007 08:49 AM
jzingo
Oct 26, 2007 06:34 PM
venom
Sep 18, 2006 04:38 PM
jesse
Apr 2, 2005 10:11 PM
