Idler pulley
Old Nov 29, 2006 | 10:09 PM
Default Idler pulley
Randy:
I may need to replace an idler pulley. I have a blower, and it is the one immediately underneath the blower pulley. I have a 2003 4.6 motor. The surface is worn and has a cupped appearance.
Can you help?
Old Nov 30, 2006 | 05:22 AM
maybe, is this pulley a factory Ford one or one that came in the blower kit?
Old Nov 30, 2006 | 12:36 PM
foncarelli's Avatar
Everyday Im Hustlin
I have replaced mine just about every year.
Old Nov 30, 2006 | 06:29 PM
I just replaced mine, squeled and had some play in the bearing
Old Nov 30, 2006 | 08:37 PM
Randy, it should be a stock one. I don't believe any pullies came with the blower except the blower pulley. This si the one right beneath where the blower one is located.
Blake
Old Nov 30, 2006 | 09:50 PM
THe number 9 pulley?
Old Nov 30, 2006 | 10:32 PM
Yup...that looks like the one. Thanks!
So, foncerelli what hapens to yours?
Old Dec 1, 2006 | 05:24 AM
$13.70 + shipping and in stock
Old Dec 3, 2006 | 01:41 PM
Cool Randy. I think I am going to replace the tensioner too. I have reason to believe it may have some issues. Can you give me a price on that?
Old Dec 3, 2006 | 01:42 PM
Randy, can ther entire tensioner be replaced? Or, just the pully on it.
Old Dec 3, 2006 | 07:27 PM
My idler pully started to squeak at about 60k miles since the bearings were going bad.
Old Dec 4, 2006 | 04:49 AM
Ford only sells it as a whole asbly, $41.05 to you + shipping and in stock
Old Dec 4, 2006 | 06:36 PM
foncarelli's Avatar
Everyday Im Hustlin
Those P1SC's seems to wear them out. The entire drive system gets a beating. I have replaced power steering pumps, 2 altenators, 1 idler pulley, and 2 tensioners
Old Dec 4, 2006 | 09:44 PM
Randy, how do I know if the tensioner is bad? How much of an effort is involved in replacing one?
Old Dec 5, 2006 | 05:20 AM
easy to replace, chances are if the pulley is bad the tensioner is not far behind. how many miles? what is the condition of the belt?
Old Dec 5, 2006 | 06:31 AM
The belt seems thin to me and is a bit beat-up on the outside edges. I don't have a new one to compare. BTW, with an otherwise stock 2003 motor and a Novi-2000, do you know what belt I am supposed to use? I can't read the numbers off the current belt.
I have a 2000 car with 67k on it. Last May, I swapped in a used 2003 motor that now has 12,000 miles on it (4,000 since theh swap). What I don't know is which pullies and tensioner was used. I guess I would assume that they came from the new motor, but I don't really know.
Blake
Old Dec 5, 2006 | 06:37 AM
well the stock belt is a JK6-941 which is 6 rib and 94 1/8" and belts are normally good for 40 to 50k so it might be time for a new belt and tensioner
Old Dec 8, 2006 | 12:56 AM
ok...stupid question: Do you use a stock belt with a Novi-2000?
Old Dec 8, 2006 | 01:41 AM
no
i got this from MPH.
Originally Posted by 68 GT
what size is your pulley ?
mine came with a 3.4 blower pulley on my 2000 Novi kit but it also was a kit for the intercooler. Mine is 107 inch 6 rib Gates belt. $45.00.
take your belt in and compare it to a 107 inch, and go from there. Just make sure you flatten them out completely when comparing them.
you could call up paxton and ask them.
Old Dec 8, 2006 | 03:20 PM
****, I don't know what the dam size of the pulley is. I too have an I/C and run 10 lbs of boost.
gotMACH04
Sep 2, 2009 10:17 AM
Stang Girl
Jun 26, 2007 10:31 AM
May 25, 2006 11:41 PM
Feb 2, 2006 09:50 AM
Ponyman460
Apr 11, 2005 06:44 PM
