Shifter Question!!!!!
Old Nov 27, 2006 | 11:37 AM
Apollo240's Avatar
Default Shifter Question!!!!!
Does anyone have a pictures of either the Steeda Tri-Ax, MGW, or Pro 5.0? (I have an 03 Mach) Im leaning towards the Steeda b/c they say it sits closer to the driver, has a longer handle, and is height adjustable. I figured pictures would show how close it sits to the driver.
Thanks
Old Nov 27, 2006 | 11:42 AM
StormsGT's Avatar
1320 Number of the beast
I have a Hurst billet plus and love it.
Old Nov 27, 2006 | 11:47 AM
+2 w/ the Hurst. However, I prefer the 8"X3" stick from a 1st Camaro over the one that comes w/ it (8.6"X2.5").
Old Nov 27, 2006 | 01:10 PM
Apollo240's Avatar
How close is the hurst to the driver? I want the one that brings the stick closest back to me.
Thanks
Old Nov 27, 2006 | 01:47 PM
Unfortunately I can't answer that now since I'm up at college at the moment. However, it isn't to difficult to measure. First, decide where you want your hand to be when you shift (if the shifter was in neutral). Measure from the mounting point of the stick to the point where the ball/handle of the shifter would be in your hand. I don't think the Hurst sticks have an ofset in them going sideways so if you need that, a Steeda stick can placed on it but then you might as well get a Steeda shifter. However, if you find that you don't need the stick to be ofset sidways and just be laidback, than go w/ the Hurst unit. Personally, the Hurst fit me just right but for different sized people, they may need a different sized stick.
Old Nov 27, 2006 | 01:54 PM
i have the hurst too...im trying to find a smaller stick because the one that comes with it is way too uncomfortable and too tall (i switched to my stock stick, its higher but since the stock stick has more of a bend its closer to me)...im looking into getting the MGW blue handle stick cause its adjustable height wise and pivot wise
Old Nov 27, 2006 | 02:07 PM
Check out the stick from the 1st gen F-body, it isnt as tall but it has 1/2" more lay-back and is what comes w/ the SST version.
Old Nov 27, 2006 | 02:13 PM
ill check it out also
but here is a pic of the hurst w/ stock stick in first gear....it looks like it @ stock height
Old Nov 27, 2006 | 05:20 PM
Sorry, this is slightly off-topic but nice trim. Is that a kit or did you paint the pieces?
Old Nov 27, 2006 | 05:25 PM
theyre painted....im redoing it again this coming weekend cause its starting to chip due to poorly preping it
Old Nov 27, 2006 | 05:46 PM
eventer289's Avatar
Old Nov 27, 2006 | 06:02 PM
eventer289, take out the shift stops..you dont need them
Old Nov 27, 2006 | 06:19 PM
eventer289's Avatar
I know, they are not set, they are still screwed back all the way to be out of the way. I just didnt take them out.
Old Nov 27, 2006 | 06:46 PM
Seems odd that all aftermarket companies sell their shifters w/ stops. If you set them correctly according to instructions, there's no need to remove. The problem comes when you don't put adequate clearance between the stop and shifter causing you to shift into gear but to be in that gear just barely so that under certain conditions, the trans may throw you out of gear.
Also, PureStang, what paint did you use? I'm thinking of doing the same since buying a trim kit is a little too pricey and I need to save every cent I have for my 5.4 swap.
Old Nov 28, 2006 | 10:12 AM
the shifter sits in the same place.. it's the handle that changes location.
I use a pro5.0 shortie handle and a tri-ax. Reach is a little long going to 5th but other than that it's really nice.
Here's a pic:
Markstung70
Jun 23, 2007 09:31 AM
phil_the_thrill
Oct 20, 2006 06:41 AM
triggertap79
Oct 10, 2006 10:54 AM
pepsiaddict
Sep 9, 2006 03:07 PM
'01BluStang
May 24, 2005 07:27 PM
