'95 Mustang GT start up problems
Old Sep 21, 2006 | 08:21 AM
'95 stang Gt's Avatar
Thumbs up '95 Mustang GT start up problems
My 95 GT just shut off on me while driving on the freeway. As I was slowing down I tried putting it in gear and clutch starting it to no avail. Once I pulled over I got a jump start and the car started but then turned off within a minute. After that it will just crank over but will not start. Anyone have similar problems? Thanks for the help
Old Sep 21, 2006 | 03:06 PM
cobra1923's Avatar
Could be coil or ignition control module on the distributor. You don't have an alarm, do you?
Check and make sure you have fuel pressure (stick something in the schrader valve on the fuel line while the ignition is on). If it sprays out, then you have fuel and it is a spark issue (which could be coil or ignition control module). I have a buddy with a '95 and he had to replace his a few years back.
Old Sep 21, 2006 | 04:46 PM
bang!
+1
If the engine cranks you have bad ignition or coil etc etc etc
if the battery is completely dead ya got a bad alternator
if the batt has a charge but won't crank the the solenoid is to blame
Old Sep 21, 2006 | 05:01 PM
sounds like the TFI is bad.
Old Sep 21, 2006 | 07:30 PM
Smile Thanks guys
I fixed the problem it was the ignition. It had a chunk of metal missing from where it is connected.
Old Nov 1, 2006 | 05:51 AM
94IVGT's Avatar
compcams04
Originally Posted by GREG@SN95
bang!
+1
if the engine cranks its not automatically a ignition problem, if the battery is completely dead it doesnt mean your alternator is automattically bad, and the final thing if the battery is charged and car wont crank doesnt always mean solenoid either. there are others things fuel pressure, is the cranksensor working, the second thing you could have something in the car staying on a switch stuck on for something in some system draining the battery, and the last part what of the ignition switch, or the prndle switch for autos or even the clutch safety switch for manuels. theres more possibilities out there than what you stated. just letting you know.
Old Nov 4, 2006 | 02:56 PM
cobra331's Avatar
yup
Old Nov 4, 2006 | 03:10 PM
oh yeah...
but in his case these are the most probable
goldtop76
Jul 9, 2010 02:27 PM
3.8LMustang
May 1, 2008 12:17 PM
triggertap79
Apr 26, 2007 04:06 PM
dusterguy28
Jun 4, 2005 09:25 AM
bambam21
Feb 4, 2005 01:15 AM
