2005-2007 GT engine in a 99-04 body
Old Sep 30, 2006 | 08:02 PM
Silver2kGT's Avatar
Default 2005-2007 GT engine in a 99-04 body
Has anyone thought of doing this or done so already? I know a lot of people are doing 5.4 2v swaps....
Old Sep 30, 2006 | 09:21 PM
yup....search for the member 3v2000gt i believe...he is the first person to put a 3v in our cars
Old Oct 3, 2006 | 10:52 AM
the heads will mount to any ol' 4.6 block from what I gather. The big issue is the motor mount system changed from pre-05 to the 05+ models which makes getting the new block into an old car something of a problem. No worries... use an old block.
Old Oct 3, 2006 | 07:59 PM
Silver2kGT's Avatar
From what I've heard, the 3 valve heads flow almost as good as 4v heads yet are cheaper. I'm thinking of doing this or switching to a 5.4
Old Oct 3, 2006 | 09:39 PM
jadartt's Avatar
I'm sure if I wasn't so lazy I could look it up, but what parts would it take to facilitate this swap? The 3v heads swap I mean.
Old Oct 4, 2006 | 08:31 AM
how about a 5.4 with 3V heads. That could be made to sing.
Old Oct 4, 2006 | 11:15 AM
GT Ninja's Avatar
If one were to get the 3v 5.4, what all would be needed to do the swap? Would it be the same swap as the 2v 5.4 in addition to maybe the ECU and wiring harness or would the stock one work with a custom dyno tune? I know I wanna go with the 5.4, but now i'm looking at head options, and I know the 4v requires a lot more work.
Old Oct 4, 2006 | 01:45 PM
3valve heads will bolt to a 5.4 for sure. They are modular engines for a reason. And redneck made a valid point the new 05-06 4.6 blocks have a different engine mount system then older cars did. I think puals high performance allready makes adaptors to put older 4.6 motors in the new bodys but not the other way around.
Old Oct 4, 2006 | 02:05 PM
so could i just buy 3v heads and but it on my original 2v engine?
Old Oct 4, 2006 | 02:06 PM
I wonder if you could just drill and tap the block to accept the old mounts since most of the time, the OEMs would just add bosses for the new mounts and leave the bosses for the old style, just not drilled and tapped. I know this can be done w/ Pontiac blocks so I wouldn't be surprised if it's the same here...
Old Oct 5, 2006 | 09:47 AM
3v heads would be fun to tune and intake options become limited, particularly with a 5.4L since no adapter plates exist for it and truck intakes are too tall. Still, it's possible. All things bolt together, just sometimes you need a spacer.
Old Oct 5, 2006 | 09:58 AM
GT Ninja's Avatar
What if you used an intake from an 05-07 Mustang and moved the battery to the trunk so it has a cavity to be used for the filter on the driver side?
stevevs32
Jan 26, 2014 08:26 PM
krazypony
Feb 6, 2008 05:26 AM
New Products
New American Muscle Products
Jan 5, 2007 05:05 PM
New Products
Dec 27, 2006 01:05 PM
RCTrucker7
May 27, 2006 08:34 AM
