STeeda Pullies worth it????
Old May 8, 2005 | 03:55 PM
NoKturnaL's Avatar
Moderator
Default STeeda Pullies worth it????
How much HP do Steeda Pullies help produce? are they worth getting? How much time could they help take off at the 1/4
Old May 8, 2005 | 04:50 PM
Blue02GT's Avatar
Ex Mini Smack King
That's a hard question.
How much HP are they worth? 5-8 I think
Are they worth it? I'd say yes if you take into account the low price.
I trapped a little higher with mine and seat of the pants it felt as if it pulled a littler harder in the upper rpm's.
With these mod motors most bolt on's are 5-10 hp gains, other than cams 15-30 there really isn't any huge gains to be had with just one mod. You can do full exhaust, intake and pullies and gain 35-40 hp.
Old May 9, 2005 | 07:16 AM
its worth it, if you want to go faster. every bit of hp makes you go faster, i'll take every bit i can get.
Old May 9, 2005 | 09:46 AM
Lunati's Avatar
Whats that Whining Noise?
Post
u can tell a difference once u add them. i unno how much they will help in the 1/4 mile though. probably jus a lil bit. but whatever it takes to go faster.
04 Dark Shadow Grey GT
Steeda underdrive pulleys from MT
Accufab TB combo from MT
stainless steel bumper letters from MT
MAC cold air intake
15% tints/ front window tinted all the way 2
Old May 9, 2005 | 07:24 PM
owentl's Avatar
Default Install?
How hard are the Steeda pullies to install? I just got a set in but have not had time to attempt install.
How long did it take to install? Were the instructions from Steeda right on? Is there any better instructions anywhere?
Old May 9, 2005 | 07:40 PM
mike sweeney's Avatar
Senior Gear Banger
If you have an impact wrench and a harmonic balancer puller it takes about 5 min.
Old May 10, 2005 | 03:24 AM
madmatt's Avatar
Traitor...lol
You also have to have a pulley puller for the crank pulley if Im not mistaken. Dont rush it, follow the directions as they are correct, and you wont have any problems.
Old May 10, 2005 | 05:37 AM
dont reuse the stock bolt use the one steeda supplies. you need a torque wrench as well. get a uneversal joint for the impact gun. the one i used was too big radiator got in the way.
Old May 10, 2005 | 06:57 AM
00steeda's Avatar
Panty DropR
Well worth it!
Old May 10, 2005 | 01:51 PM
i hope you didnt do that. the one given to you form steeda is for getting the pulley started on then you take it off and install with stock bolt.
Old May 10, 2005 | 06:02 PM
owentl's Avatar
Is the crank pulley hard to get off? I got a puller today and went at it pretty good, but it didn't budge?? I was a little afraid to really get after it being on the crank and all.
I had to use an end wrench because the middle part of the puller was too long to get a ratchet or impact on. Do I have to move the radiator to get an impact on it?
Old May 11, 2005 | 05:03 PM
owentl's Avatar
I finally got it..
There is a thick washer between the crank bolt and the crank. Once you remove that the pulley comes right off (using a puller of course). I sure didn't see that in any of the write ups on the net..
oh well..
Old May 11, 2005 | 07:20 PM
Originally Posted by owentl
I finally got it..
oh well..
Write your own up then...
Lots of people could use that helpfull information.
:read2:
Old May 11, 2005 | 09:19 PM
dsg_gt2004's Avatar
Booty Master
If you plan on getting supercharged any time in the future, i see them as a waste of money. You have to have stock pullies on when getting supercharged. If no supercharger is in the future, go for them.
Old May 13, 2005 | 05:37 AM
Mustang Tuning's Avatar
Mustang Tuning Sales Manager
I've heard claims of 2 tenths in the quarter with Steeda pulleys. I don't know how true that is though.
Old May 13, 2005 | 09:38 AM
Insidher's Avatar
yesh its worth it ive notice a decrease in my 1/4 mile it was about 2-3 tenths i have mine set at 14 deg ... i was running about 14.2 before and with the pulleys on i ran 13.9 was the fastest but i average 14 flat i got a 99 GT coupe
Old Jul 5, 2005 | 09:13 PM
Lightning247's Avatar
Huge Member
The steeda pullies are a worthwhile mod in my opinion for a bolt on N/A application. It has it's downsides and upsides. I for one had to run a stock alternator pulley as with the one supplied from steeda it did not hold a good charge...downside, although it doesn't happen to everyone.
To underdrive the waterpump however improves cooling when not idle in traffic as decreasing the speed of the water pump at high rpm reduces cavitation.
All in all its pretty bang for the buck. 2 tenths in the 1/4 however I'd be a little skeptical, maybe with a timing adjuster too. But it's not out of the question.
Philip K.
Old Jul 5, 2005 | 10:48 PM
4.6 Love's Avatar
Cheap easy mods= worth it in my book!
Miguel
nbakid23
Sep 21, 2006 02:59 PM
TEXASPAUL
Feb 11, 2006 07:16 AM
NoKturnaL
Dec 23, 2005 11:36 PM
saleen50
Dec 15, 2005 05:10 PM
E'sStang03GT
Dec 26, 2004 03:32 PM
