check engine light
Old Sep 11, 2007 | 09:17 AM
new2mustangs's Avatar
Default check engine light
I recently purchased a 2002 mustang gt it has had the catalytic converters removed and replaced with magnaflow exhaust. I did not know this until after i bought it and the service engine soon light came on. I had the computer read and it showed bank 1 sensor 2 o2 sensor was bad. I bought some mil elliminators but the light came back on after about 15 mi of driving. My question is do I need 4 mil elliminators or is ther something else that needs to be done. I placed the 2 that I bought on the rear to sensors then moved one of them to the front sensor when the light came on the first time but it did not help. Any suggestins would be appreciated.
Old Sep 11, 2007 | 09:23 AM
the front 2 sensors are the ones that matter. hook the MIL eliminators to the rear 02 sensors. if your check engin light comes on get the codes and google obd2 codes and look up and see what it says.
to reset the check engine light disconnect the positive battery terminal for 15 minutes. that will reset your computer
Old Sep 11, 2007 | 10:00 AM
mpt_1962's Avatar
when you reset the computer does that remove the tune if you have one? Do you need to flash the computer again?
Old Sep 11, 2007 | 10:04 AM
no the tune will stay with the car. your stock tune is stored in your handheld tuner.
Old Sep 11, 2007 | 10:18 AM
i will put both of the mils back to the rear and reset the computer and see what it does. Thanks for the input if anyone else has some more suggestions feel free thanks again stanger00
Old Sep 11, 2007 | 10:39 AM
Does it matter which batt. cable that is removed for 15 min poss. or neg. just curious to know/
Old Sep 11, 2007 | 12:53 PM
positive
Old Sep 11, 2007 | 02:07 PM
cobra1923's Avatar
If you have a handheld tuner, you should be able to turn off the rear O2 sensors? No need for MILS
Old Sep 11, 2007 | 02:16 PM
It amazes me that people put MIL's on the front 02's.
Old Sep 11, 2007 | 02:22 PM
The negative terminal should always be disconnected first, not the positive. Disconnecting the positive first can't cause a short. So, to clear the light, disconnect the negative terminal.
Old Sep 11, 2007 | 03:04 PM
i answered someone elses question not the thread starter. i doubt the guy who started this has a tuner.
Old Sep 11, 2007 | 10:07 PM
ok Mr 03gtmustang I have put the mils on the rear o2 sensors reset the computer and once again got the service engine soon light. The code that i get is p0136 you tell me what I should do now.
Old Sep 11, 2007 | 10:48 PM
oohsoobad2's Avatar
Some MILs are junk. I tried two different sets with no luck. You may need a chip/tuner to disable the CEL for good.
Old Sep 12, 2007 | 08:22 AM
PO136 This code refers to the second oxygen sensor on Bank 1. The O2 oxygen sensor produces a voltage between .1 mV and .9 mV. The ECM monitors O2 sensor voltage and determines if exhaust is lean or rich. O2 sensor voltage is high when exhaust is rich and low when exhaust is lean. The ECM monitors this voltage and increases or decreases fuel injector pulsewidth according to engine fuel/air ratio. If the ECM detects low HO2Sensor voltage for an extended period, it will set P0136 Conditions required to set: HO2 sensor voltage is low for longer than 2 minutes (minutes depend on model of vehicle. Could be up to 4 minutes)
so bank 1 is on the driver side. O2 sensor 2 is the rear sensor. so switch your MILS around and see if the code changes.
Old Sep 12, 2007 | 11:15 AM
mpt_1962's Avatar
damn...i guess he knows whats up with the problem.
Old Sep 12, 2007 | 11:56 AM
thats just basic troubleshooting and researching skills. i guess the air force taught me something
Old Sep 12, 2007 | 02:27 PM
Something a lot of people dont know how to do.
Old Sep 12, 2007 | 03:13 PM
oohsoobad2's Avatar
Yep.... people still dont believe me when I tell them Autozone will read the CEL for free. Dealers charge $100 to hook up to their scanner.
Old Sep 12, 2007 | 03:54 PM
After I drove the car with the mils in the rigth spot I gto the same code from auto zone p0136. So i swapped them around left to the right and right to the left I will see if the service engine light comes on again. If it does I will go back to auto zone and see what code I get then. Thanks stanger00 you have been good help all of this computer crap is all new to me. Ford's have never been at thetop of my list but I really like the mustang aside from the check engine light it runs real strong.
Old Sep 12, 2007 | 04:10 PM
oh hell yeah ohhsoobad2 you would be a fool to take a car to a dealership for a check engine light. just about all of the part stores do it for free.
Joyrider564
Jan 18, 2006 08:30 AM
95STANG
Oct 26, 2005 09:24 AM
97stanger
Sep 11, 2005 08:48 PM
"94" 5.0
Apr 21, 2005 09:34 PM
HappySavage
26
Mar 13, 2005 03:18 PM
