Fuel Injectors
Old Aug 24, 2007 | 08:00 AM
Chasinsparks's Avatar
Default Fuel Injectors
I have 2004 Gt, With Steen Racing heads Comp 270 Cams Mac long tubes 70 MM Throttle body and Plen, SCT Custom tune by Steen Racing Dyno'ed 314 Rwhp 317 Tq, It was said that my injectors were maxed and I should go to atleats 24lb injectors. With that said
* would I need a retune
* will there be any real benifit to upping the injectors
* any suggestion on brand
Old Aug 24, 2007 | 10:37 PM
i was told to wait for 24's until i get the heads put on...but since you have heads on go ahead and get the 24's...then get it retuned
Old Aug 25, 2007 | 07:56 AM
your stock 04 injectors are 21lb. If they were 19's I'd say yeah definitely upgrade too 24's. At 21/22lbs you should be fine but you are approaching where I'd upgrade so might as well. You're at least taxing their duty cycle pretty heavily at WOT.
Tuning will have to be updated and the maf curve re-done for the bigger injectors. It's a minor update with only usually 2 dyno runs needed to check AF afterward.
I like Ford branded injectors... they're Bosch. Most correctly fitting squirters are bosch made but might as well go FRPP from Randy. Venom also makes nicely blueprinted units.
Old Aug 27, 2007 | 10:13 AM
Default Thanks
Hey Thanks for the reply
Old Aug 27, 2007 | 10:39 AM
oh i didnt know the 03 gt's had the 24lb injectors...i didnt ask my tuner about an 03 because i thought they had the 19's also. Well once again red knows all...lol
Old Aug 27, 2007 | 10:48 AM
they don't... they have 21lb injectors. The 02's do too. 01 and down have 19 on GT's
Old Aug 27, 2007 | 10:51 PM
opps...sorry meant to say 21's. Whats the hp rating that the 21's can hold up to red? What can the 24's hold up to?
Old Aug 28, 2007 | 08:24 AM
depends on the duty cycle and fuel pressure. Normally I'd say if you cross the 265rwhp mark that you should look to 24's. My handy dandy calculator says 21's are starting to be taxed at stock power levels. Cross 285bhp and 24s become a need to stay under 80% duty cycle at WOT.
I have to use 32lb units for my new motor.. you do the math.
Old Aug 28, 2007 | 08:34 AM
that is quite a bit of math. Do you have an excel document with the "input your numbers" for it to calculate it for you? Ill be around 270-285hp after the cam install. So i should look into upgrading injectors to 21's on my 2000? Or just wait til i get it dyno tuned to find out if im running lean at WOT? Actually you said 24's after 265 hp...so maybe even 24's IF my engine is running lean though right?
Old Aug 28, 2007 | 08:50 AM
Go to Holley's website. They have a good calculator to determine the appropriate injector size for you.
Old Aug 28, 2007 | 08:53 AM
with 270rwhp you should be burning gas for at least 315bhp which causes me to say, time for 24's. It's better to go in with enough injector than to lean it out to find out there wasn't enough flow in the first place.
Remember... I'm keeping you at or below 80% duty cycle.
Old Sep 5, 2007 | 12:41 PM
bossman302's Avatar
Forgive me if I hijack this tread but looks like I need to get 30 lbs injectors for my new engine. Since the ford racing injector’s state the will now work with a stock MAF will the turner be able to recalibrate the stock MAF to work?
Old Sep 5, 2007 | 12:50 PM
it's not the maf being calibrated so much as the transfer function associated with it. The only way to properly tune AF ratio is via that, so yes. Your tuner will be able to hand curve the MAF xfer function and you'll be happy as a clam. Most handhelds come with injector options including 30lbs built in. They're never perfect so I still recommend a dyno run with logged AF to check it out.
Old Sep 5, 2007 | 01:00 PM
bossman302's Avatar
Thanks bro, just wanted to check. Was a little worried.
v6'stang
Apr 30, 2006 12:55 PM
KSUPKT
Apr 22, 2006 07:26 PM
I<3MySnAke
Feb 20, 2006 05:19 AM
I<3MySnAke
Feb 16, 2006 04:45 PM
Nov 25, 2004 05:27 PM
