89 5.0 fuel pump not turning on, please give me e hand.
Old Jul 20, 2007 | 04:39 PM
89foxtrot's Avatar
Default 89 5.0 fuel pump not turning on, please give me e hand.
My fuel pump in my 89 LX hatch is not turning on. i have checked cut off switch and relays, all seem to be good. any ideas?
Old Jul 20, 2007 | 07:00 PM
thunderchikn's Avatar
well if u have already checked the relay and inertia switch then theres only one thing left to do,check the connector at the tank,its a pink wire with a blue trace,see if u have 12 volts when you have someone cycle the key,being thjat theres only a 2 sec buzz. if you have power then u gotta drop the tank and pluck the pump out.
Old Jul 22, 2007 | 07:47 PM
89foxtrot's Avatar
i'll give it a try, do you know which mustangs that have the fuel pumps mounted outside the tank?
Old Jul 22, 2007 | 08:53 PM
yours should be in the tank,unless it has an aftermarket external pump.
Old Aug 5, 2007 | 09:36 AM
jeds'91_stang's Avatar
if its bad id highly recommend a bigger pump. The stock ones a POS and if you have to pull the tank might as well get a better one that will support mods later one. Ive had a 190LPH in mine for quite some time. I swear it made a difference on the top end, if i remember right the stock pump is in the 80-90LPH range witch is pathetic for a V-8.
Brent Bowers
Jul 5, 2007 06:29 PM
coasterman
Mar 18, 2007 06:22 AM
dannyb785
39
Apr 28, 2006 08:39 AM
Icefreezen
Oct 9, 2005 02:09 PM
4.6 Love
16
Jun 27, 2005 02:33 PM
