Some issues.....
Old Jul 19, 2007 | 05:47 PM
Default Some issues.....
After installing the intercooler I am having some questions...Am I supposed to lose 3-4lbs of boost? Others told me like maybe 1lb, but I took it to redline today just to see how much boost I was getting and I only saw 5psi. I am on the 8psi pulley and normally saw 9psi...Pretty sure I dont have a boost leak anywhere, it idles and runs fine. Also how will my tune be affected by this? I mean will it run rich because I am seeing less boost, or will it adjust itself according to the boost? I am on the 3.60 pulley right now,so do I need a 3.12 to see 10psi??
I know for sure that I need a bigger bypass valve. Its giving me alot of compressor surge if I rev above 2500-3000 rpms...How will this affect the car until I get a bigger one?
Old Jul 19, 2007 | 05:49 PM
I would change the pulley and see what kind of difference it makes. it could rule out the boost leak, or confirm it.
there isnt a kink in your boost gauge line, is there?
Old Jul 19, 2007 | 06:30 PM
dont think theres a kink, but I havent checked....Ill go look in a few minutes....
Old Jul 21, 2007 | 11:39 AM
El Diablo's Avatar
Maybe belt slippage?
Old Jul 21, 2007 | 04:18 PM
Adding an inter-cooler means lower temps. Lower temps means less pressure, right. So, if I am not mistaken, I think you should see less boost.
You should swap pullies now and you need a tune. Adding colder air is a different ball game. I am no expert, but I think this merrits some consideration.
Old Jul 22, 2007 | 11:44 AM
well I didnt think that lower temps is the cause for less boost but it could be. I know that colder air will lean out the a/f ratio because theres more oxygen, but if im only seeing 5psi then I think that would make it run rich. Going to order the bypass valve soon and the pulley so I can get it tuned...after i check for boost leaks
Old Jul 22, 2007 | 12:40 PM
you should see 1-2psi less in most cases because the intercooler causes a restriction thats where the boost loss comes from. You got to have a leak. I would think you should do ruffly 7psi with that pulley. If you got 9psi before then yeah its low.
Old Aug 10, 2007 | 09:16 PM
White04GT's Avatar
KenneBell Blown
did you ever find out what was wrong?
Old Aug 11, 2007 | 11:49 AM
nope, but theres not a boost leak thats for sure. I checked all the couplers and theyre not leaking any air while the engine is running.....I havent had the $$$ to get everything bought and tuned yet. Im in the middle of saving for 4 months rent while im in school this fall, engine bottom end parts, and working on getting it lowered so its not looking like a 4x4 anymore...All will come in due time. Just alot of things going on....
JackThe Ripper
Apr 14, 2008 09:35 PM
SuperSonicGT
Order Status ?'s
May 30, 2005 10:23 AM
wildride5.0
Apr 13, 2005 07:07 PM
SLVR04GT
Feb 17, 2005 03:47 PM
Jeremy
Jan 28, 2005 07:06 AM
