Wide band O2 use
Old Jul 12, 2007 | 08:35 PM
copracr's Avatar
Default Wide band O2 use
I'd like to get my a/f ratio looked at cause I just did some pretty major surgery to my car. My understanding is that a wideband O2 will tell me an exact a/f ratio. Can I get an approximate a/f ratio from one of those cheap gauges that hook up to my O2 sensor? I just want to watch my a/f for lean conditions, and those wide-bands are a bit over-priced.
Old Jul 12, 2007 | 09:10 PM
I wouldnt put a price on making sure your a/f is in the right place.
Old Jul 12, 2007 | 09:36 PM
Blitzmann's Avatar
Only way to be safe is with a wideband, the cheap ones wont give you an accurate reading. Plus I wouldn't check it myself if I was asking this question in the first place. Seek a professional!
Old Jul 12, 2007 | 10:19 PM
2Eighty1's Avatar
All the cheap ones do is give you a fancy light show, they do not tell you any information that you can use.
I would buy a good wideband (Dynojet WBC, LM1, etc) or go get a dyno from a shop that can monitor your AFR through the tail pipe probe.
Old Jul 15, 2007 | 09:38 AM
the narrowband sensors can't tell you anything useful. At full rich reading they're actually just telling you it's richer than 14.7:1. Wideband or nothing at all... I have the Innovate Motorsports LC-1 hooked to my Autometer A/F guage. Works great.
Old Jul 15, 2007 | 10:58 AM
copracr's Avatar
OK, but if I'm aiming for 12-14:1 then I'd need to be a little under 14.7:1, right?
While i'm idling or at part throttle the O2's will be switching, so they will be useless there. But when I punch it the reading will stabilize and I can correct as needed. Sounds reasonable to you?
Old Jul 15, 2007 | 02:50 PM
jwarnick's Avatar
The widebands are the only way to go. The cheap ones are just for show. I wouldnt trust the cheap ones for nothing. A wideband are the only ones to trust
Old Jul 16, 2007 | 10:13 AM
no... pay attention:
narrowband cannot tell you HOW MUCH below or above 14.7:1 you are.. just that you are to one side or the other. Narrowband FTL, Wideband FTW.
If you don't do wideband you're making pretty and meaningless lights appear.
I'm a cheap bastard and I'd let you cheap out if you could but you can't so please don't. Buy an LC-1 or LM-1 and when you get it, if you need help hooking it up, lemme know and I'll send you some helpful notes.
Old Jul 16, 2007 | 10:16 AM
steve_stang2003's Avatar
How do the widebands hook up, say in a permenant set up?
Do you remove your stock O2 sensors and plug in the WB unit?
Or do you drill holes in the pipes?
TIA.
Old Jul 16, 2007 | 01:05 PM
copracr's Avatar
[QUOTE=r3dn3ck;277303]no... pay attention:
QUOTE]
OK, this is what I needed to know. So many posts about being "a pretty light show" didn't really get at this.
tr6nut
Mar 20, 2008 06:53 PM
PureStang
Feb 2, 2007 12:31 PM
Larrybia
Nov 26, 2006 07:04 AM
Rabbit
Aug 30, 2006 01:34 PM
roushrider81
28
Oct 27, 2005 07:54 AM
