Smoke at WOT
Old Jul 9, 2007 | 01:08 PM
94IVGT's Avatar
compcams04
Default Smoke at WOT
Smoke at WOT
94 GT 5.0l
less than 1000miles on motor
moly rings
vortech s/c 8lbs
new twisted wedge heads
cometic mls headgaskets
140psi on all cylinders dry test
no smoke on startup or cruising
is this normal at wot? what would be the cause of this?
Old Jul 9, 2007 | 01:19 PM
SynisterMustang's Avatar
Are you trying to say your tires are smoking? or the engine?
how long did you break it in before you started going WOT? more info?
Old Jul 9, 2007 | 01:21 PM
where's the smoke coming from?
Old Jul 9, 2007 | 04:32 PM
94IVGT's Avatar
compcams04
its blue smoke from the exhaust. im not burning oil any other time, no puff at startup or when cruising. theres about 900 miles on the motor
Old Jul 9, 2007 | 07:03 PM
you shouldnt be going WOT yet.....the rings need to be seated first
Old Jul 10, 2007 | 08:26 AM
yeppers.. that's the most likely cause. ring seal isn't complete. be nice to it..then flog it.
Old Jul 10, 2007 | 03:56 PM
what kind of rings did you use? me freind and i just built his 327ci chevy with a brand summit racing carries, i forget the name i wanna say seal pro but i will have to find the box. Anyhow it smoked like a bitch and had shitty psi on compression test we swapped out the rings with good ones now its 180psi in all and no more smoke and more power.
Old Jul 11, 2007 | 12:32 AM
94IVGT's Avatar
compcams04
they were sere sealed power rings
Old Jul 11, 2007 | 08:32 AM
what's the gap and how much boost when the smoke starts coming out?
Old Jul 11, 2007 | 10:51 AM
94IVGT's Avatar
compcams04
machine shop installed so i dont know gap, smoke starts at about 6-8lbs
Old Jul 12, 2007 | 05:48 AM
cobra1923's Avatar
Sure it's blue?
Could be black maybe?
What type of fuel management do you have? If you're running a FMU it could be running too rich when boost comes on?
Old Jul 12, 2007 | 08:53 AM
Good point... if it's pulling that rich it would probably look a bluish grey to black (depends on how rich) and if it's waaaaaay rich it could well be washing down the cylinder walls and burning the oil that solvates off them allowing a bluish-white smoke to emit but not in especially large volumes. In any case, to be of much more help you'll need to see someone up close and personal that is familiar with such things.
Old Jul 13, 2007 | 11:11 AM
94IVGT's Avatar
compcams04
its deffinately oil. Rick at anderson ford told me to take the oil cap off and put a breather on so i did, and that fixed the smoke at wot problem for a few days, now yesterday it blew the breather out and started spewing oil out the valve cover.
Old Jul 18, 2007 | 01:30 PM
trystrom's Avatar
Need to do a leakdown test and figure out where that engine is leaking down--that will tell ya where that oil is getting in at.
corey
Nov 7, 2006 06:48 AM
PureStang
Sep 23, 2006 11:28 PM
95cobravert
Feb 9, 2006 10:32 PM
Bruce Peter
Sep 13, 2005 02:44 PM
Mar 25, 2005 09:36 AM
