4:10's Vs Supercharger. Issues?
Old Jun 28, 2007 | 04:05 PM
4.10s are the awsome with boost, on the street it makes for lots of fun, at the track with real tires it makes for a fast holeshot.
Old Jun 28, 2007 | 04:23 PM
I personally, wouldnt run any type of roots or twin-screw setup with 4.10s. Centrifugal would be the way to go, and at your elevation, I would make sure its intercooled or aftercooled. You will pretty much have a tire roasting machine so instead of changing out them gears, id do full length subframes, FRPP uppers, MM lowers, and a nice set of shocks and struts. Itll help alot with wheel hop and thats probably your main concern regarding snapping your rear end.
Your sumis are a hard compound tire and will be screaming for mercy instead of launching you to the moon, however, the suspention will also help you in the traction area. Our rear ends are stronger than most people make them out to be. As long as you arent wheel hopping againts cracks and potholes in the road and launching with slicks, itll hold up.
Old Jun 28, 2007 | 04:45 PM
If you dont want an intercooler or aftercooler, you can look into meth injection. You can pick up a nice kit for 500 bucks and it runs off, well methanol. You can get concentrated windshield washer fluid and use that and itll last a couple thousand miles depending on your driving habits. My washer fluid bottle has been empty for years, and you can use that tank instead of adding a new one. You can buy boxes of concentrated washer fluid for cheap, and pretty much every place should carry that stuff.
Old Jun 28, 2007 | 04:54 PM
mcmmotorsports's Avatar
Resident Mental Patient
Jack, I had/have 4.10's in my 04 5spd car with my Vortech and I would not have done it any other way. You will enjoy it.
Old Jun 28, 2007 | 05:24 PM
caballo's Avatar
Exceptional Member
I personally think the 4.10's will keep the rearend from letting go as long as you don't use slicks. The weak link in the deal stays the tires, until traction is increased. that's when you need to invest in some HD rearend components(when you start wanting traction).
Old Jun 28, 2007 | 05:52 PM
3V2000GT's Avatar
46MONSTER
build your engine,trans,rear end then add booooooooooost. if you break something you will be selling the SC to cover it.
Old Jun 28, 2007 | 06:01 PM
caballo's Avatar
Exceptional Member
The voice of reason rears its' ugly head. Back,Damn you! Back!!!
Old Jun 28, 2007 | 06:35 PM
Might wanna check out some meth injection websites and read up about it.
http://www.snowperformance.net/
http://www.coolingmist.com/
and even google it up.
Old Jun 28, 2007 | 07:56 PM
TheManInBlack's Avatar
i myself built my rearend because of my future plans of a vortech. ive seen these rearends scatter with a n/a motor on slicks. for the small price of axles and a limited slip carrier wouldnt u rather have peice of mind? especially if ur gonna be throwin nearly 400 horse to the wheels.
Old Jun 28, 2007 | 08:06 PM
Sweet!
Now all i gotta do is draw out picstures for 4 childrens puzzles, one with Dinosaurs, one with ladybugs, one with butterflies, and one with firetrucks.
lol...
they are gonna pay me $500 a pop if they like em.
lol...
Old Jun 28, 2007 | 08:37 PM
machnjo's Avatar
I pretty much got the same advice and info about running a s/c with 4.10s and an auto. Definitely go with a centrifigul type, either paxton novi or a procharger. I'm working on getting a Procharger D1-SC atm and plan on running around 15 psi. I'm thinking it'll be a hoot to drive.
Old Jun 28, 2007 | 09:03 PM
i dont think you will break a rear end running a supercharger and a automatic. i have a built tranny and my rear end is holding up just fine. the only thing i suggest to do is to do the J-mod on your valve body. that will firm up your shifts for those WOT blasts. pulley wise who knows theres a guy on MPH running a 3.1 pulley non-intercooled in 6k elevation with 400 hp. my 3.1 pulley intercooled has me at 12 psi sea level.
Old Jul 3, 2007 | 01:33 PM
dookie2365's Avatar
has no legs
+1
RUYELLO
May 14, 2010 06:29 AM
SuperSonicGT
Order Status ?'s
May 30, 2005 10:23 AM
wildride5.0
Apr 13, 2005 07:07 PM
SLVR04GT
Feb 17, 2005 03:47 PM
Jeremy
Jan 28, 2005 07:06 AM
