my front rims/tires
Old Jun 2, 2007 | 05:44 PM
theponyfactor's Avatar
Default my front rims/tires
Well I took off my front set and put the stockers on and my car doesn't pull and it drives a hell of a lot nicer. So I'm wondering if maybe it's the tires being cheap? (Fuzion ZRi) Also when I had my alignment done, I had it done with the stock rims on because they said that they didn't want to scratch my chrome because of the clamps they use. Is there an alternative to this so I can get an alignment done with the fr500s on?
Also I was wondering if anyone knows if they make 17x7 (not 9) fr500s in case the rest of this doesnt fix it....
Thanks.
(In case some of you saw my FS thread, I'm all over the place and now I think I'm keeping it...lol @ myself).
Old Jun 3, 2007 | 08:22 AM
Ghostalker's Avatar
BOLO 4 ME
Lol, out-dated alignment machines... they are using ones that can't grip the outside of the wheels... your alternative is to go somewhere else with newer machines, although it really doesnt matter, the alignment hardly takes the wheels into consideration, its more about the spindles. (edit: ie you can put your fr's back on without any change)
And no, I dont believe they make anything in 7... stockers are x8, most aftermarket are x9... I am sure it was those crappy fuzion tires you were using. Not that I am rolling on p-zero's or anything, I have mastercraft avenger HP's in 245/45/17... what size ZRi's were they on your 17x9s?
Old Jun 3, 2007 | 12:39 PM
i have 275/40/17
looking at my receipt from when i bought them, it says i bought lifetime new tire wheel bal parts/labor and lifetime rubber valve. so hopefully they can do something for me.
Old Jun 18, 2007 | 09:50 PM
WhitePony's Avatar
Funny...i have the same problem. the alighnment device they have uses lazers and they cant align my rims because there is no lip on them.
Also do not run 275's on the front...i am right now and the inside wall rubbs alot. you should check it. im going to put 255's on the front i think.
Old Jun 18, 2007 | 10:01 PM
its not the alignment thats your problem, its those wide tires. Your alignment settings wont change with the FR500's on. Told you before its because theres so much rubber on the road that it catches all the imperfections on the road surface.
Old Jun 19, 2007 | 06:08 AM
this thread is old...and mine dont rub
PColav6
30
Jun 5, 2009 09:43 PM
SilvertGT04
Tire and Wheel Talk!
Dec 4, 2006 03:17 AM
majik_420
Feb 26, 2006 06:10 PM
tripleblack
25
Jun 22, 2005 07:57 AM
SMOKIN'05
May 26, 2005 12:25 PM
