Trouble Code: P1151
Old Jun 11, 2007 | 08:55 PM
stage2roush2002's Avatar
Roush #6147
Default Trouble Code: P1151
What is this and how can I fix it? Also my air/fuel gauge turned off when this code appeared. Any suggestions???
Old Jun 11, 2007 | 09:29 PM
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
Old Jun 12, 2007 | 05:13 AM
Roush #6147
How can I fix this?
Old Jun 12, 2007 | 06:13 AM
either bad sensor or some sort of vaccum leak is making it run to lean on the passenger side of the motor.
Old Jun 12, 2007 | 11:59 AM
Roush #6147
So replace the o2 sensors?
Ford was just messing with my exhaust recently....could this cause anything?
Old Jun 13, 2007 | 02:16 PM
Roush #6147
Anyone?
Old Jun 15, 2007 | 07:56 AM
stngmn96's Avatar
Get the car lifted and crawl under it and see if the person who last worked on it damaged a wire to the 02 sensor, it is loose or damaged. If all is well, while under there just check the exhaust bolts and the two bolts which hold the H or X pipe you have to the header. This is an easy course of action and can help you eliminate these area's from the list.
Old Jun 15, 2007 | 09:43 AM
Roush #6147
Alright will do. Thanks
tluckie13
Jan 10, 2010 07:07 PM
v6'stang
Dec 11, 2009 07:23 AM
stage2roush2002
Jul 15, 2007 07:39 PM
stage2roush2002
May 18, 2007 07:49 PM
ShapeShifter
27
Nov 16, 2006 10:11 PM
